Possible solution for 'Plug and Play' fitting of an amp
Jonathan_Pow
Hi there,
On my search for an 'ideal' subwoofer installation for the new Leon I have come across the Metra 74-9003 Plug and Play Line Output Converter:
http://enfigcarstereo.com/shopsite_sc/store/html/METRA_74_90003.html
It may be a solution for those of us that are reluctant to interfere with the original wiring of the Seat Leon, yet want to install a subwoofer.
I have read Davros' guide on the forum
http://www.seatcupra.net/forums/showthread.php?t=117628
but am not fond of the idea splicing the speaker cables. (Though it is quite a simple solution)
Granted, I haven't bought or installed the Metra 74-9003, but have sent an email to the manufacturers asking if they can give any reasons why it wouldn't work.
Comparing:
and
I don't see that it wouldn't work, but I will wait with baited breath for the forum and manufacturer response.
Jonathan_Pow
Two replies... but which one is it.
I have just had a reply from Metra with the following:
"Unfortunately it will not work as the 9003 harness and your harness are reversed."
I am currently away from home at the moment and unable to get to my car, so would anyone be able to confirm this as being correct or not?
The supplier reckons it will fit... however if the harnesses are 'reversed' it would be an easy thing to miss with just the above photographs as reference.
Cheers,
Jonathan
Zipcode
295
Brackley, Northant's
I'm pretty sure there is a parrot harness that costs about 20 quid which just plugs into your existing harness and gives you the line out connection. It's on one of the sticky posts on the main MK2 page i think.
Feb 1, 2010
987
Leicester
Any ideas were mate. I have searched but can't seem to find it
holmefield
Forever messing with cars
Oct 20, 2013
578
I've consider a subwoofer, a plug and play would be a lot less hassle me finks..
