PROSPORT
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Readers Rides
Readers Rides Show us your ongoing projects / work in progress / pride and joy.
Reply
Thread Tools Rate Thread Display Modes
Old 27-12-2007, 19:20   #1
roly
midnightmotors.net
roly's Avatar
roly has 10 points
My K04 hybrid powered MK2 Cupra Sport track slag (it's now left the building)
Some of you will know a bit about the car but i thought i would post up the details from the start (it'll take a while so bare with me )
I purchase the car back in nov 2004 as a standard 2.0 16v cupra sport and decided it would be my sensible run about, i had all intentions of keeping it reletivly standard bar changing the exhaust and suspension but that wasn't to be.
After replacing complete exhaust system, panel filter, suspension, wheels and brakes i was happy with the look and drive of the car but wanted more power.
Decision time!! do i buy another mk3 cupra or convert this to 20vt power?? after trawling through ETKA and comparing parts etc i decided i'd have a go at the conversion (bearing in mind im not a mechanic by trade so would be learning as i went this was a kind of big task for me)
I found a doner car on good old flebay and after trailoring it back from Coventry set to work literally pulling the car to pieces. 2 weeks later the shell was sent to car heven and then the real fun began.
1 week on my mk2 rolled out of the workshop, housing a new 20vt engine and complete wiring loom (inside aswell) it took me another 4 weeks to get the car to a standard i was happy with but it looked almost factory when it was done.
Spec list as of 22/01/2012
Engine
• 1.8 20v engine bored to 1847cc
• Wossner forged pistons (82.5mm, 8:5.1 compression ratio)
• Scat forged conrods with 20mm wristpins
• Supertech black nitride intake and inconnel exhaust valves
• Backdraft motorsport baffled sump
• JBS05 hybrid turbo
• Forge K04 actuator
• K04 exhaust manifold
• Forge manual boost controller
• 4 bar fuel pump
• Devils own water methanol injection
• Braided fuel lines
• 386cc injectors
• Evoshield gasket
• Forge 200 series universal intercooler
• Custom intercooler pipe work
• Green cone filter
• Forge 007P recirculating dump valve
• Badger5 3” tip
• Vibratechnics race engine mounts
• Badger5 3” downpipe and decat
• 2.5" scorpion cat back system
• Wideband lambda sensor
• EGT sensor
• ABS pump relocated
• Relocated & bypassed N249 & N112 valves
• Carbon canister removed
• Secondary air pump and associated parts removed
• Setrab Proline SLM oil cooler with braided lines
• Oil catch tank
• Badger5 custom map
Transmission
• Neuspeed short shifter
• Lightened 2.0 16v flywheel
• Sachs racing clutch cover
• Sachs racing organic clutch plate
• Peloquin ATB differential with uprated bolt kit
Suspension
• KW Variant 3 Coilovers
• TT bushed front wishbones
• Omp front upper strut brace
• Neuspeed front 25mm anti roll bar
• Neuspeed rear 28mm anti roll bar
Brakes
• Brembo 4 Pots with ferodo DS2500 pads
• Standard rear discs and pads
• Dot 5.1 brake fluid
Wheels
• 7x17 Compomotive MO’s for road use
• 3mm front spacers
• 15mm rear spacers
• 7x16 OZ with Toyo R888’s for track use
Exterior
• Standard 16v front bumper with ghetto moddification for track use
• Standard 16v rear bumper
• Standard 16v side skirts
• Standard 16v boot spoiler
• Factory fitted carbon look B pillar trims
• Factory fitted carbon look rear number plate trim
• MK1 leon wing repeaters
• Osram indictor bulbs all round
• Rear wiper removed
Interior
• MK3 Ibiza dashboard and wiring conversion
• Custom Cages 6 point bolt in roll cage
• Sparco Circuit Bucket Seats with alloy side mounts
• LUKE 5 point harnesses
• VEMS digital wideband AFR & EGT gauge mounted in custom fascia
• Autometer boost, oil temp and pressure gauges mounted in custom fascia
• Manual window regulators
• All unnecessary wiring removed
• All sound deadening removed
__________________
roly is offline   Reply With Quote
Old 27-12-2007, 19:27   #2
roly
midnightmotors.net
roly's Avatar
roly has 10 points
There were a few teething problems to start with, airmass, N75 etc but with everything replaced the car ran sweet and even turned out to have a remaped ecu which was a bonus.
This is where the real probs started, i was happy with it for a while but then decided i needed more power (as you do) since the initial build almost 2 years ago the car as undergone various changes and i've thrown a small fortune at it.
Pics below show various states of play over the last couple of years and a few of the build process
__________________
Old 27-12-2007, 19:40   #3
roly
midnightmotors.net
roly's Avatar
roly has 10 points
__________________
Old 27-12-2007, 19:44   #4
roly
midnightmotors.net
roly's Avatar
roly has 10 points
As it stands today
Next mods will hopefully be custom made oil cooler and a baffled sump, eventually i'll go BT conversion aswell
__________________
Old 27-12-2007, 19:57   #5
DaNnY_LaD
Big Turbo Leon Cupra R
DaNnY_LaD's Avatar
DaNnY_LaD has 10 points
Have you got any bits of that yellow cupra as i need a new foglight
__________________
HTA-GT2868R Leon Cupra R Built By INA Engineering & AKS Tuning
DaNnY_LaD is offline   Reply With Quote
Old 27-12-2007, 20:01   #6
roly
midnightmotors.net
roly's Avatar
roly has 10 points
none at all it was scrapped almost 2 years ago
__________________
Old 27-12-2007, 20:10   #7
jenk
Senior Member
jenk's Avatar
jenk has 10 points
Top work bud, this has to be the most complete mk2 on here.
__________________
I wish it looked this good......
http://www.jenk.me.uk All my mixes are here!!!!
jenk is offline   Reply With Quote
Old 27-12-2007, 20:36   #8
driveforward
Is at the Nόrburgring
driveforward's Avatar
driveforward has 10 points
Hats off to you sir!
A classic example of:
"I'm not modding this car!"
"It's staying standard"
__________________
BMW Z4M Coupe
driveforward is offline   Reply With Quote
Old 27-12-2007, 21:10   #9
crezz
pedro motorsports
crezz's Avatar
crezz has 10 points
you should be really proud mate, i would love mine to look half as good as yours. it is so sweet
crezz is offline   Reply With Quote
Old 27-12-2007, 21:24   #10
tris
The Daddy
tris's Avatar
tris has 20 points
All I can say is what a car and to think that you did it all your self mate
TOP JOB!!
tris is offline   Reply With Quote
Old 28-12-2007, 10:06   #11
redcupraboy
Senior Member
redcupraboy's Avatar
redcupraboy has 10 points
Wow what an absolutely lovely mk2, well done with the mk3 cupra engine conversion, its a right stealthy bit of kit, really liking the white compomotives for the rally look, used to have those on my old 106 series2 rallye, well done!!
redcupraboy is offline   Reply With Quote
Old 28-12-2007, 10:11   #12
Ibiza125
Motocross nut
Ibiza125's Avatar
Ibiza125 has 10 points
Looks great mate! That will be a little flyer!!
Ibiza125 is offline   Reply With Quote
Old 28-12-2007, 12:23   #13
roly
midnightmotors.net
roly's Avatar
roly has 10 points
Thanks for the comments, i'll try and update this thread with pics and details as it progresses throughout 2008
__________________
Old 28-12-2007, 12:56   #14
Cupra_Jay
Orange Wheels FTW!!
Cupra_Jay's Avatar
Cupra_Jay has 10 points
car looks good mate, seen it a few times already, and is really smart!! good work fella!
__________________
Black 2006 Mk4 Ibiza Cupra - 219bhp & 244ft/lb - April 2013
AmD Stage 1: Milltek exhaust, SFS TIP, Pipercross Induction Kit, Forge Strut Brace, JOM Coilovers, Whiteline RARB, EBC Discs, DS2500 Pads, FK Grille, 6K HIDs and Orange wheels!!
Cupra_Jay is offline   Reply With Quote
Old 28-12-2007, 15:48   #15
Czechboy
Tarmac terrorist
Czechboy's Avatar
Czechboy has 10 points
Top car Ben, I remember following the progression thread of this. Can't believe its been 2 years already.
Mig
__________________
NOW: GSX-R 600 + 328 Sport
Czechboy is offline   Reply With Quote
Old 28-12-2007, 16:36   #16
jamie paton
Senior Member
jamie paton's Avatar
jamie paton has 10 points
makes me almost want a mk2 again. very smart mate. how much power is it putting out at the moment.
__________________
black leon cupra r, performance torque tweaked, recaros front and rear, touran rear wiper and aero fronts,bailey dv30, BMC cda, blueflame exhaust, grooved brake discs all round, private"L30N" plate, 6000k HID's,ultraleds, led sidelights,
jamie paton is offline   Reply With Quote
Old 28-12-2007, 16:48   #17
roly
midnightmotors.net
roly's Avatar
roly has 10 points
Mig
I've still got all the pics and details saved somewhere but it would take me days to sift through it all
jamie
It was custom mapped at jabba back in july where it pulled 227 bhp & 240 lbft on k03s
__________________
Old 28-12-2007, 16:51   #18
jamie paton
Senior Member
christ that'll be entertaining mate, i bet you absolutely hump some really unsuspecting motors. i take it its got the mk3 dash as well.
__________________
Old 28-12-2007, 17:09   #19
roly
midnightmotors.net
roly's Avatar
roly has 10 points
it is good fun
suprises a few people who arn't expecting it to still be with them at xxx mph, still needs more power tho!!
full mk3 interior and all wiring loom up intill i fitted the cage and recaros
__________________
Old 28-12-2007, 18:01   #20
__B3NNY__
OEM with a 'Twist'
__B3NNY__'s Avatar
__B3NNY__ has 10 points
Superb mate. Looks like you have done one hell of a good job on the conversion. Is that the laguna dci intercooler?
__B3NNY__ is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 1180
$mila, اhoja_78, (beeza gti), -pseudonymous-, -SlicK, 03cupra, 150cupra, 182@wheelsleonj, 1986brandon1, 2 Many Ibiza's, 20vturbocupra, 221084clarkey, 2pac58, 45_CB, 4wdibiza, 5509433, 9108matthew, 932matthew, @lq!, a1exw1nter, A5HL3Y, aaronipswich, abhardwaj1990, acerman, adam b 190782, ADaM B 66, adam cupra 20vt, adam kelly, Adam R, Adam's Cupra, adam.bernau, adambullet, adamdanshona, AdamRoutley, ade1lung, Adman77, adulka, af1, ahm, ahmadabdeen, aka, Alan Partridge, Albe 20VT, Alex 17, Alex Cupra, Alex.j.89, Alex.Pearson, AlexGSi2000, alexj124, alexmatt, AlexvD, alex_shepz, alfredo, ALFYDUNC, alionka, Allan_84, allyboy, Aloy, alpinesman, AlpineWhite, Altech, alx_chung, AMartynCZ, amccan10, andrew180, Andrew@ALD, andyb, andybmk3cupra, andyj, andy_tratter, Anthony090684, antnee, araz, ArcticCupra, armyboi01, Arnie, ArosaRacer, Ashley32, Asi_20VT, astraman18, ath55, ather`s, attila_tdi, audiintegra, AusCupra, AviTurbo, ayacoub92, az20vt, A_Calvert, Backdraft, Badishi, BaezoN, ballyg, barnsley, barold, bart820, basil, Bazzle, BCM, beattie17, bedz, beezertart, ben450, Ben:, BenHartshorne, benny12357, BenO, Berg, bete noir, big phill, big rich, Big-Pete, Bigcheese, bigdur, bigox213, bigpmofo, bigtb, Big_daddy, Big_Lad, BIG_Y, binka1000, binky, black magic 20v, Black TDI Turbo, BlackDeath, blackdream, blackdriver, Blackjack3d, BlackLeon, Blackpearl__, Blanco92, blueskull, blue_bird, bobmcgod, BocanegraTom, Bojeto, Bokac, boltyz, bonet, Boo, BoOKi, boost_addict, Bora Sport, Bover, Bowen, bowenthepunk, bozzzydmc, Br!dges, brad1, Bradley Ibiza, Breezapom, brett123, brindlestaff, Bruce J, brummel, brunobski, brwmogazos, bubba, BubbleBoy, bubbles1, BuckRider, BumbleJC, burnsey, Byggis, C11PRA DC, c5tto, caino_123, Cali-Cupra, callam, Calum_Cupra, Camaleγo_Ibiza, Can I Live, Canners89, cap r 225, captin_urbis, carlsoundwave, Carr20vt, catflam2, CerberusStyle, CGD217, Chambers_CUPRA, cheesyquaver, chipmunk82, chris1788, chris285, chris96sx, chrisbell, chrisby, chriscupra02, ChrisCurzon, Chrisdaman, ChrisMansell, chrisrulzz, christian1988, christianomoe, ChristianSWE, Chriswaite130, chris_200120vt, Chris_C, chris_ffx, churcherj, CIarkie, cila555, Ciosmi, CJRamze, Cna1406, coco_cupra, ConradJellyfish, coomber, coops10, Copa33, Copey, Copper Cupra, Cordy_Matt, CORDY_SXMAN, Corza, Cos, coulam123, Covps2blue, cpcpeter, CraaigFR, crack5111, Craig Senior, Craig1985, craigp87, craigturbo, Craigus, CraigW, crazyd, crespo1987, crezz, crispyjay, critch4, Croc, crossedmike, CrossyR, cruffy69, csd_19, cup001, Cupra Grant, Cupra Kev, Cupra Kid, cupra-8v, cupra-barn, cupra-J, cupra-neil, Cupra., cupra.al, cupra/chris, Cupra137, Cupra20, cupra2001, cupra20vt240, cupraajy, Cuprabav, cuprabaz, CuPRaCaN, Cuprachris1990, cuprachrissy, cupradan, CupraElliott, cupramillo, CupraMuscle, CupraMVR, cuprapowerpaul, CupraSeanTDi, cupraslayer, CupraTurbo81, cuprawill, Cupra_160, Cupra_20vT, Cupra_Cleo, Cupra_Jay, Cupra_J_RS, Cupra_Red, cupra_tan, Cuproy, curlykarl, cus, Czechboy, D.K, Da rossy, dai cupra, dai2ice, Dajmin, dalegolf215, DaleGT, Damian@integrated, Damo, Damoegan, Dan Cupra R, dan1990, danb4lur, DanCupraET, DanGB, danger_dave, Daniel 1.8t, danielc16, DanielFaith, Danjw, dann, Danny123, dannyboi321, DannyC87, dannycam, dannygoodson123, dannynoon1993, Danny_B, DaNnY_LaD, danp1uk, Danturbo225, Dan_Biza_Boi, Darren FR150, darrenh, darren_mcvicar, dash, dav3, dava, Davem, davescupra, Daves_ibiza, dave_gti, dave_ph, Dave_R, David.vtR, DavidN, david_alpine, David_smith_909, davie, Daz8161, daza b cupra, DazWood, Dazz 1989, Daz_Wilko89, dc1984, dday, Deanf, deedaskrh, deek_cupra, deftones, delcac, denzil691, DerbyForget, dervpower, Devoncupra, dfawbert, dice36, digit, ding-dong, dingdom, diss_50, djkobra, djpix99, DK_CupraR, DK_MK2, dmmsta, dmvcompany, Dobby, Doctor Gonzo, Dogzilla, Dolly_Gti, Don't walk, donie, doug16v, drifter07, driveforward, DrunkenDubber, dubmanic, dubroots125, dubste2, dunc_b, Dyl J, Eastanbul, ebo007, Ed King, edpeckham, edwards_a3, ed_barnes, egypt, EL, Elcopaturbo, eleriroberts, EmDee, emlyn11, Empi5, endeem, EnGbudd, envycordoba, eppy, Erijaso, esso, Estoril Ben, eurodoba, evo2345, f1btn, F2 Cupra Matt, F2 Ed, F2 Stu, fenix_vk, fever, fezz, fiestaboy, Finan, Fisher, Fl@pper, flame blower, flappy, flegz16, fliptron, FLK, Flyin Scots, Fordy_FR, fourtwofive, Fox god, fozzy890, frankmabo, fr_craig, FR_MATT, fuel injected, Gabre, Gar3th, garrethaubrey, gary bocking, gary1986, gatman, gavbey, gav_1, Gaz5350, gazcuprablk, gazR, gb, george130, GeorgeF, george_seamons, Gersen, gezmeister, gib9060, Gibon, Giz, Glunken, godzuki, golfgtikiw, Goo, GraemeC, GrayT, GReddyRx7, greesha, GregP, groovesalad, gti gadge, GTi T, gticupra123, gtimassive, Gtrane, Guncha, gupi_singh, Guppy, gussie53, gussy, h17och, hamlyn, harry_mr2, Hartosh1, harty190486, hawtin1584, HAYLEY_TDI, headhunter, henri, hertzov, higgi, Hilla LCR, hoggers, Holdup, HOLLANDMSGH, holty, hopkinsgm, hopper, HuKu, hussain, Hypersonic, H_man, Ianm83, ian_cupra, ibiza 1.0, Ibiza 130 tdi, ibiza boy, ibiza matt, ibiza power, Ibizaκιας, ibiza-carl, Ibiza125, ibiza@kev, IbizaAlex, ibizaboi, ibizacupra, ibizacupra172, IbizaCupra1987, IbizaCX, Ibizajones, ibizaluke, IbizaMarksy, ibizatom, ibiza_1.4tdi, ibiza_95, Ibiza_Cupra_BGD, ibiza_mero_2010, IBIZA_W1LL, ibizouba, Icecavern, ickleginge, IH786, ilikefatgirls, ilya, Immunda, in10sity, Indy, interceptor.med, ipece, J4M1E-LRN3R, J4mie, J4SON14788, J@mes, jackbmx2004, JacketJ, JacobG, jam666999, jambel, James.Judd.1, jamesypyk, james_cupra, James_LCR, jamie paton, Jamie7, jamiebennett81, jamielee, jamieread, jamit01, jase874, JasKandola1, Jay.., JayCho, jayman303, jaymd, jaypee, Jayz, jayzer, jcs356, jc_boc, jd26, Jdizzy, JDUB 20V, jenk, jenyz, Jerkyist, jernjackson, Jimbo76, jimbo_h, jimgti52, jinidos, JKM, Jmerrie, JMP, jmrgtturbo, JMS, JoγoOliveira, jodie, JoeCav, joehirth, Joel_Lucketti, Joens, joewl92, Joey350, John-Cupra_TDI, johnboii225, johnn., john_tdi, Jokerman261, jon23, jonathanp, jonisginger, jonjay, Jonny555Robz, jonny5fingers, Jonny791, Jonny95 SXE, jon_boi_91, joostdeblok, Jordanwaterhous, Josh m, joshbro90, joshz, Jotag, jpcibiza90, jrallye, jt20vt, Juan lcr, Juclassic, Jugo23, Juhuts, jumbies, jumpinjackflash, jwilkinson, K03heco, k30nyg, kacer, Kai_1600, kane.cullen, kares, karim, KarlMac, karlosR, KennyPOLO_Gti, kenny_fr, KFC91, kiko_zizo88, killbill, killer205, killieboy123, kingy89, KIWI16V, Klone, knackerdecobre, knight, knight85, KP, Krash, kris166, Kris@Forge, krisbutler02, krispoland, Kryptix, ktulumike, kurtbil, kyle18uk, Laggo, Lambie, lanceneoman, laz1, lc4geoff, LCR-Luke, LC_15, Lee C, Lee Edgecombe, lee_woollett, leighwinter, Lela_CRO, Lentδjδ, leon130cv, Leon1600s, leonbeastmk1, leoncp11, leoncupra666, leoncupraRlee, LeonFRDave, leon_lib, Leth, Lewis_B, lexyy, Liam6871, liam86, Lil_DosS, Litago, living2xs, LJCupra, LMJ, lm_gauci, lockly, Lodgey180, lofer, lovlirikal, Luixy, lukin90, lupocharged, M1KEH, M4TTYF, MAC MAC, mac64, mag, MagicFR, maikblackcupra, manks88, marccowley1, marcus_cupra, MargheD, MARK IBIZA FR, mark-cupra, MarkE, Markie68, markillo, marklar, markmeus, markojay, mark_eisner, Marmalizer, Martin M, Martin_DSG, MartyP, master_ABF, Mat, matek55, Matt S!, Matt-18, Matt-V5-Duffy, matt88 lcr, mattdavies, MattFrench, Mattgriff90, matthab, Matthewd91, Mattwood, mattyh3, matt_s, Matt_Tomlin, matylad, Maverick777, maxvan, mayfair86, mazzerati, mc funbot, mcsolle, MDS, mekonj, MexxT, MichaelMr, Mickle, Mickylad, Mikael92, mike pedder, MikeR, MIkey kc, mikey88, Miller 20vt, miller 666, Mindplay, mini80, minimandan92, mini_hammy, mirass, mjdodsworth, MK21147, Mk2Ibiza, Mk2steve, mk4 cupra, mmmatt, mnmnmikey, Mo Arif, moink10, mojoex, monkee, monkeybann, monkgti, morgangrinder, MORGZ, mossie045, mosso, MostWanted, Mr Cellotape, MR OBD, mr.leatherday, mrannikk0, MrBen2k7, mrcreeky, MrNorma, Mrski1, mrtijn, mrwookie, Mr_Dave, MTW, MuirrayM_, munnracing, Murdered LCR, Mustii, MWG, Mylo, myslilyyli, Mythbuster, N3 CPRA, nads, naollie, narly_bail, nat85, nate03, Nath., ndbrgr, ne11er, nealo, Neil1, Neil82, neilopafc, nev, Nev_LCR, Nick2008, NickLCR, Nick_J, nightflight, Niktron, Nimshoi1, Nimzy, nok, nolan2k8, nossi_20v, Novataken, nozzy15, ntrueman, Nutkin, nutty_merka, nutzu, NWhiteley, Oj 89, oldeboi, Ole, olethalb, OliMonty, ollie23, OllieL, olvie, oneofthetwins, oojammyflip, orangemuffin, orons, P1N3R, p34ch3y, Pander, parkeravfc, PastyBoy, Pat15312, patang, patchb, paul gilbert, paul-murphys, paul-with-seat, Paulocordy, ped, pedrosousa, perikolos, pete88, peter_cupra197, Phat Busted, PHAT-CUPRA, phey708, phil8vgti, philsip, PhilW, Phooo, Phuture, PID, Pidge, pietwillem, Pingu101, pj1985, pjdj, PnP, Polky2, pollard1, Poncho.:R, pontifex, Poochy, porki, posterboy, Poundie, Poverty, prawn, Presha, pretty boi, pricey_2k10, Proffitt, Proff_CUPRA 180, projectgingawar, provocation, proximo, PuntoGT, pwb17, Quicksilver20vt, R1ch85, r214, r2d2hp, R4cup, rabcupra, rafko, RALF, Rasser73, Ravey_Cupra, RC79, Readie46, red1.4, Redcupra20vt, redcupraboy, Redemption, redrobo150, rees, REMAX, Reuvers, revo, Revo Kev, revo20vtdan, RevoMark, rf860, rg72, Rgm racer, rich td, rich-t, rich.h44, richardcupra, Richie20VT, richybigman, richypanic, rich_cupra, RickC, rifflections, rob321, Robbie C, RobDon, robertj, robertnitro, robjnr, robk2009, Robsadaddy, RobT, rocket_ronnie, ROCKS-87, Rocky Rocastle, RoDiK, rogers, rokero, roly, roman6k2tdi, RonBurgundy83, Ronin225, ross p, ross.b, ross27, rosshutchie, rOtah, RPM-tuning, RS777, rsulam, rubjonny, rudolf2, Russ_tdi, ryank, s1l3nc3r, s20ty c, s24-k1, S800BRN, SA Polo, sa06, sambryant, SamIbiza, sammy18, samslow, sarahtdi, Scam, scintex, scooot, Scott-o, scott5, ScottForbes, scottthompson09, scott_y1, ScrewedSkull, scruffydubber, SeanCorky, Seanyt, Seat _Ibiza_6k1, Seat-Chris, seatcupramad23, SeatDanny, Seatfahrer90, Seatmann, seatperrie, seatturbopower, Seether, sergi0, shaneyb, shaun8215, Sheff's Cordy, sheffboy, sheperd, sheriiff, SICEY, Siim, Sile-R, Silver1.6-Sport, simonthekane, simon_709, Sin, singh123, sionowz, sionw, sjc59, Skorchio, SKOT, sl1m1thy, slapbladder, slpdesign99, slydog18, Small, smallhalls, smiffymk3, smokescreen, Smoki333, sm_cupra, snafu, sortu, Southie, Spacyuk, Sparkk, spelfor, speters2001, Spirit Furtive, SPLeon, Spud_G40, Squar, squarehead, staneko, stani540, starkygti, starletcraig, ste4232, stef cupra, Stefal639, stev, Steve, steve m, steven878, stewbie55, stezo2k, Stitz-Cupra, STOCKY, STom, stonechip1, STPCG, strugers1, sTTickman, stuartcrosk, stucupra r, suj, sumerz, surreyfull, suukmiideek, swilky23, T. Spark, t.oldaker, t0m, T108, T31LUK, talaatibiza, tarzan, tchoff, TDI PEP, TDIEDD, tebotsc, tedvagas, TeensyDevil, tel19, ter981, Tfsi_Mike, The crow, The MoffMeister, the passenger, thebody, thePHILosipher, the_maz, Tiago_bnr34, TiggsGTI, tiler, tills7, TimR1.4SE, tiwe, Tizer, TJenkos, TJP, tobi20v, toledo399, Tolgahan Ures, Tolly, tolly_tdi, Tom Duff, tom w, Tom., Tom.S, Tom0StarC, Tom173, Tomer 20VT, tommy2008cupra, tommyk22, tomtom., TomTomTom, tonijov, tony696, tonycane, tooshy, towaportsmouth, Toxic, Tr1ck, TRCUPRA, tris, trotters, truCido, Trueman, truss, TSVB, TTRR, tubbsy, Tunerko, turbo009, turbo87, turboboy, turbojoe1980, turbomart, twig, twiggy91, tyrrell, UFO Yellow, Undert4ker, uzy, vagfam1, venner, venom tdi, vershizzcupra, vgmve, Villon, vita.srutek, VivaGT, vngtx, Void, Von_Rod, vroomtshh, VRSLOZ, vts16v, Wash It!, Watson©, wazza5, welly, westallc, Whitechapel, whitey2206, whitey987, WhiteyCupra, wigz45, wild willy, will7291, Willie, willisthm, Willlee81, willpr, Willxr, Wilson, wilty bitha, wilz, Winner, wisejason, wkd450, Wolverine1091, Wolvo-Oleg, Wolvotim, woody1986, wrayvon, wre, xavier de, xreyuk, y4n, yellonvi-R, yellowbeezer06, Yellowdevil, YIN, zander999, zeksy1, Zero T, ZeroCup, zeroSignal, Zesnale, zieluch99, Zlash_eX, _chris_, __B3NNY__
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Mk2 Cupra or Mk2 Cupra? Jamin Berry Ibiza Mk2 9 08-01-2008 07:43
My black Mk2 Ibiza Cupra 16v and Jib's red Mk2 GTi 16v Roelνch SEAT Pictures 8 06-08-2007 16:48
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
