25-07-08
I'm Nils, 24 years, and I come from the Netherlands.
This is my car since the 25th of july 2008.
Seat Ibiza 1.8 20vt FR
Build 07-2004
Mileage 66.000 km
Besides a leather interieur it's fully optioned
Cupra front bumper
Cupra back bumper
Everything sprayed in color
Fog light plates in color
Keyless doorhandles
2006 back screenwhiper
Really looks new
I'll use the first posts to keep up my project. Click on the multiple images to view the complete picture gallary's.
05-07-2008
Pics when I bought the car
29-07-2008
Forge Split-R
Today I mounted a Forge Split-R and I ve done the N249 mod
The sound is a bit disappointing. Maybe it gets better when I get my remap.
Also I mounted my Alpine HU today with Ipod interface adapter and I began to mount my JBL compo speakers in the doors.
And just made an appointment with JD engineering. The best 1.8 20vt remapper from the Netherlands
13 august is my time!! I'll get a custom remap at a dyno.
08-08-2008
I mounted an original pre-facelift FR bumper on my Ibiza. With the cupra bumper I don't have a good working intercooler and than the custom remap would not be the effort.
Also got my turbo pressure gauge and oil temperature gauge mounted.
Bought a Pipercross foam filter
13-08-2008
Visited JD Engineering today!!
He also programmed the car so I don't need my air flow meter anymore. Right now I can let my Blow Off Valve, blow off all air without any problems.
This is the result of JD:
The Torque really is amazing. The top performance could be better, but than I would have to mount another exhaust and a front mounted intercooler. I'm really happy with the results of this standard FR.
Now doing:
214 HP @ 4800 rpm
341 Nm @ 3300 rpm
18-08-2008
The Previous owner of my Seat Ibiza FR 1.8 20vt with smic, mounted an Cupra bumper on the car, but as I was planning to get a custom remap at a dyno, I had to find a solution to get back a good working intercooler. A front mounted intercooler from Forge or the original one from a Cupra (D) cost over a 1000 Euro without mounting. So I modded the Cupra bumper to get some cold air into the smic.
To make sure my modifications work, I've done some logging with Vag-com of the inlet temperature with my pre-facelift FR bumper and the Cupra bumper
First I drove my car easy to normal work temperature (About 95°C on my oil temperature meter). Then I make sure my laptop was ready to log group 4 of Vag-com. This group logs the engine RPM against the inlet temperature. Then drove to 1000 rpm in third gear an than floored to 6500 rpm. All logs were done on the same day with the same outside air temperature and humidity on the same road.
- FR Bumper log 1 - Outside: 19°C - Oil: 97°C - Water: 97°C
- FR Bumper log 2 - Outside: 19°C - Oil: 100°C - Water: 100°C
- Cupra Bumper log 1 - Outside: 19°C - Oil: 97°C - Water: 97°C
- Cupra Bumper log 2 - Outside: 19.5°C - Oil: 100°C - Water: 96°C
As you can see the inlet tempereture get's much higher on the second run with both bumpers. Can you imagine how much power loss this gives when you step on it for only ones.. I did not do a third run, but it could be the power loss would even be more as the turbo warms up the intake air even more when the engine is getting warmer and warmer. This also is because I modified my car to run on much higher turbo pressure and the intercooler is not optimal for that amount of air.
The best thing is that it's very clear that the intercooler does a better job with the Cupra bumper mounted, as it is with an original FR bumper. All my work was not for nothing.
08-08-2008
Repaired the FR rim. It was damaged when I bought my Ibiza. Click on the picture for a before/afte gallery.
10-09-08
Bought some cleaning products today. I did not have any before since I live in my own appartment so I bought everything at ones at an carcelan specialist.
Kärcher high pressure water cleaner
Meguiars - NXT Generation Car Wash Shampoo
Meguiers - Quick Detailer
Meguiers - Medium Claybar
Meguiars - NXT Generation Techwax 2.0 pasta
Meguiars - Color X
Meguiars - Gold Class All Metal Restorer
Wheelwax - Wheelwax
Poorboys World - Trim Restorer
Meguairs - Ultimate Washmit
Valma - Soft spons
CarClean - EZ Detail Auto brush
Mothers - Wheelbrush
CarClean - 2 sided mini brush
3 Hi-Tech - Foam applicator
Lake Coutry - Red Ultra Soft Foam Hand Polish Applicator
Poorboys World - Waffle Weave Drying Towel
Poorboys World - Deluxe Mega Towel Yellow
Poorboys World - Deluxe Mega Towel Coral
12-09-08
I cleaned my car in two days for about 12 hours. Really did a good job cleaning all parts with a brush that are usually forgotten like all doorpins and seams
results:
Build 07-2004
Mileage 66.000 km
Cupra front bumper
Cupra back bumper
Keyless doorhandles
Really looks new
05-07-2008
29-07-2008
Forge Split-R
08-08-2008
13-08-2008
Now doing:
214 HP @ 4800 rpm
341 Nm @ 3300 rpm
18-08-2008
08-08-2008
10-09-08
Meguiars - Color X
Wheelwax - Wheelwax
Valma - Soft spons
12-09-08
results:
