LCR W.I.P Update K04 Hybrid- F23 Here, mini review page 50
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Hi all,
I have been doing a lot of work on my engine bay as of late, i have most of the mods done now apart from the final 2 engine bay mods which are a mirror polished inlet manifold and a CAI, but i think i am nearly there and can finally start on uprating the handling on the LCR, starting with ARB'S, TT bushes and a long list of other stuff
Mods so far:
• 318bhp and 314 lb/ft
• Tuned By TDR performance, stage 3 remap
• K04-023 Hybrid turbo.
• INA/034 High flow Exhaust manifold.
• Integrated engineering Con Rods.
• BlueFlame 3” Downpipe Information.
• BlueFlame 200 cell race cat.
• Blueflame Cat-back Exhaust system.
• Forge Motorsport Big Race Front Mounted Intercooler.
• SouthBend DXD Stage 2 OFE Endurance clutch
• SouthBend uprated clutch lines
• Badger 5 Performance Silicone 3" Turbo Inlet Pipe.
• Genesis 550cc Injectors
• NGK Iriduim XI Spark plugs heat range 7.
• Stage 2 Devils Own Water/Methanol injection kit, Dual nozzle/Solenoids.
• Forge Motorsport Diverter value, Yellow spring.
• Forge Motorsport UNOS Manual Boost Controller
• Front Upper Strut brace
• N75 and N249 Delete.
• Uprated BERU coil packs
• Golf MkV Coil pack harness surround.
• Oversized JETEX Racing Cone Air Filter
• Neuspeed Air filter Heatshield in polished stainless steel
• PowerFlex uprated dogbone mount.
• PowerFlex uprated Wishbone bushes front/back
• Eibach Pro-Street-S coilovers
• Rear Whiteline Adjustable antiroll bar 24mm
• Godspeed 330mm 2-piece grooved brakes disc
• Godspeed Rear 256mm grooved discs
• HoseTehnik braided brake lines front/rear
• NDX Bluestuff race pads, front/rear
• “Genuine” BBS CH 0014 19" Alloys In Daytona Grey.
• H&R 10mm front 15mm rear spacers.
• Forge Motorsport Top mount caps.
• Forge Motorsport DV relocation kit.
• Forge Motorsport upper and lower boost hoses.
• Forge Motorsport PCV.
• Forge Motorsport Breather Hoses.
• 5000k HID Headlights
• LED Side lights
• Polished Coolant/Steering Fluid/Oil/Washer/Dipstick/Funnel/Bonnet lift
• Polished Intercooler Charge Pipe
• Polished Inlet Manifold and Throttle body
• Custom Brian.G WMI mount spacer.
• Nomand Twin Pillar pod with Volt/Boost/Oil temp gauges.
Cupra R Alloy Dead pedal.
• Vent mounted Race Diagnostics Liquid Gauge.
• N2MB WOT BOX
• Alpine CDE-113BT Head unit, with USB, IPOD, CD and Built-In Parrot Bluetooth® module for handfree.
• ME7.5 Launch control system mapped in.
• Left foot brake & Boost mapped in.
• Smoked repeaters
• Debadged sides
To be fitted
• D2 Racing coilovers :)
Plus more.
Enjoy the few pics below, more update ones can be found later in the thread.
ell0070
208
Jersey, Channel Islands
That looks great. How easy are the coolant hoses to do? I've got TIP and boost hoses, but just had visions of oil and fluid going everywhere when disconnecting the originals.
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
they are easy mate, usually just a few hose clamps holding these things on, no oil or fluids to content with when changing.
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
looks good mate kinda looks like my bay but mine is white not black lol is that your bonnett release in vac line ?
Any pics, i would be interested in seing your bay, i am always looking for new ideas.
Also the blue silicone houses my electric for my boost/temp guage, i didn't like the housing it was in, so i replaced 3/4(the visible part) of it to smarten it up.
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
ah i see thats what i want to do to mine most prob my next step as well as the cold side kit
few pics
Very nice, i remember actually i seen you car in another post and it gave me the idea to spray my engine cover and battery cover gloss black, so thanks for that.
what size hose did u use for the hose that goes around just infront of the charge pipe.
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Think I used 8mm or 10 mm was a bit tight on the right hand side but went on it was the same size I used for the water and charcol filter . No probs about the painting ideab
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Its late and there is fook all on the box so i thought i would a a few pics of my LCR. I have added coilovers, rear ARB, spacers and a set of geniune BBS CH014 19" powder coated black since i updated this, there are a few other bits and bobs changed but i have mostly spent my time as of late working the paint job and detailing my bay
The jury is still out for me on the black BBS, i am toying with the idea of getting them in some sort of gun metal color, so comments are welcome
