hi, need to replace our remapped tdi boost pipes (smic - standard) as the small 90 degree pipe at the front lower (in front of drivers wheel) pipe has popped off with very worn lugs. the top pipe is seeping a little oil as well so might as well replace that too.
my question is are the pipes kits from sfs or samco any better than the standard seat pipes as they must use lugs to connect to the current system? maybe they use stainless steel instaed of alloy??
2, what are the part numbers & prices from seat for the pipes & clips?
any advice much appreciated.
