K04 MK3 Ibiza Cupra Track Ready - RIP
My Seat Ibiza Cupra in imperial blue. :D
Current Spec
Engine
K04 Turbo
BAM ported Exhaust Manifold
Stealth Racing Custom Map
Custom Down Pipe Heat Wrapped
Blueflame 2.75inch Exhaust
Green Monster Filter 80mm Neck
Badger5 V2.2 80mm Blue TIP
Walbro 255 Fuel Pump
4Bar FPR
BAM Injectors
Toyosport 600mm X 300mm X 76mm FMIC
Custom Black Intercooler 63mm Pipework
SFS Hoses For Intercooler
SFS coolant Hose
Forge Map Sensor Tube
Dump Valve Hotside
Forge 008 Dump Valve
Forge Yellow Spring
Forge UNOs In Black
Mocal Oil Cooler 16 Row
Mocal 3/4" Sandwhich Plate
N249 Bypass
N112 Bypassed
SAI Removed With Forge Blanking Plate
Carbon Canister N80 Removed
Aircon Removed
Alternator Painted Black
Drive Belt Tensioner Painted Black
Power Steering Pump Painted Black
Alternator Bracket Painted Black
Candy Blue Rocker Cover
Black Inlet Manifold
42 Draft Oil Catch Can
Pholenic Insulator Gasket
TT Platinum Spark Plugs
AQX Bolt Down Coil Packs
Blue SFS 4mm Vacuum Piping
Audi R8 Oil Cap
Audi R8 Coolant Cap
Small 1.2 litre Washer Bottle In Boot
VW Caddy Single Outlet Washer Pump
Blue Washer Tubing
Battery Relocated
0awg Wiring Running From Engine Bay To Boot
Transmision
Peloquin ATB LSD
ARP Steel Bolts
Millers CRX Competition Oil
G60 Flywheel
VR6 Clutch
8N0 711 046 TT Short Shift Linkage
Top Mounted Shifter
Custom OEM Stick
Richbrook Gearknob
Chassis
Neuspeed 28mm Rear AntiRoll Bar
Neuspeed 25mm Front AntiRoll Bar
Bilstein B16 Fully Adjustable Coilovers
Manual Steering Rack Conversion
Wide Track Front Suspension
MK3 Golf Non GTi/VR6 Wishbones
Vibra-Technics Rear Wishbone Bushes Welded In Place
PowerFlex Black Series Front Wishbone
Powerflex Black Series Steering Rack Bushes
Black Seat Sport Strut Brace
OMP Front Lower Brace
Black OMP Rear Upper Brace
AKS Tuning Harness Bar
Solid Front Engine Mount
Vibra-Technics Rear Engine Mount
Vibra-Technics Gear Box Mount
Brakes
AP Racing CP5200 4 Pot Calipers
Painted Red
295mm 8 Groves Bells and Rotors
Cosworth Track Master Front Brake Pads
Brembo Rear Brake Pads
Wheels/Tyres
Cupra R Super T's 16" X 7j ET35
Toyota T1R's
Exterior
6000K HID's
Ring Blue Indicator Bulbs
LCR Front Splitter
Debadged
Fog Lights Removed
Rear Wiper Removed
Glass Speedtec Wiper Blank
Stubby Mirrors
Black Plastic Mirror Caps
Stubby Ariel
Personalised Number Plate
Storm Single Wiper Conversion
Storm Wash & Wipe Conversion
Interior
2x Corbeau Sprint Bucket Seat
2x 4 Point Harness Blue
Momo Team 280mm Steering Wheel
OMP Boss Kit
Brown & Geason 70mm Steering Wheel Spacer
Nomad Double Gauge Pillar Pod
AEM Boost Gauge
AEM Wideband Gauge
AEM Oil Temp Gauge
Sound Deading Strip Out
Horn Switch Mount In Steering Wheel Cowling
Screen Washer Bottle In Boot
Painted Inside Rear
Battery Relocated In The Boot
AlloyRacing Battery Cage
Abit Of 0awg Wiring Showing
Comments always welcome good or bad
Chambers​
2,189
Midlands
Same lol well i already have
Just bought a diff for mine :santa:
Do like the brakes though, mine are crap and really need upgrading!
Have ya? What sort ya got? I though bout a diff the other day alot of money but worth it I suppose.
Thought you was selling it lol?
The brakes are brilliant I need to replace the rotors and pads tho as there nearly shot lol!
Apr 15, 2009
2,189
Midlands
Be good on track though, plus mine spins every gear too easy
Was selling up but the car i was selling for didnt happen unfortunately, no bother though as i dont mind keeping mine and using it on track for a few years until im 25 :)
Deleted member 35176
Looks sweet mate... alot to do in the plans you best get cracking and keep the pics coming :)
Little update for today
Right had a few things building up in me room as I had purchased a few things over Xmas, and I finally got fed up tripping over and stubbing my toe on my bumper or a set of brake discs!
So about 4ish whilst it was getting dark, I grabbed all me stuff for the car and all me tools and took them all to me missus house to take over the garage
This is how It started!
I started striping the bumper off *
And stripped all my ap brakes down as they are shot!
And this is how I left my car. Gunna hit it hard tomoz with hopefully tip fitted fmic and relocation kit fitted aswell.
Tip :)
Dv relocation kit (still waiting for some of it) / meter long pipe (Gunna use it to join the fmic pipping!) and lots of mikalor clips!
New 008 dv with spring kit!
Hopefully have a clearer day and get some better pics up instead if these rubbish iPhone pics lol
Comments as always!!
Chambers
Bit of an update
Now I have the Intercooler mounted to the crash bar and the pipe work mocked up and in place! Along with the cold side relocation kit, still waiting for things off eBay aswell tho!
Some trimming was needed
Fitted a yellow spring in my new 008 dv
Fitted my forge tip
Removed the carbon canister/N80
Next I think will be to replace the vac pipes and bypass the n249 valve whilst I wait for the postman for some clamps etc!
Oh need to flog this if Any one is intrested? Open to offers.
Also have fog lights for sale too!
Cheers Chambers
Little update and again
Fitted a TT short shift linkage which also meant I could fit everything to the forge tip
New linkage
Fitted
Old one but haven't driven the car for a week so not sure how much shorter it is but well worth it for 20 quid for the dealers
Filter etc fitted
Also got one of the for 10 quid from the dealers
Had a crack at the n249 bypass aswell
Anyone confirm Ivep done this right?
