Revive turbo cleaner - Anyone used it?
joel81
12
I was thinking of giving it a go to try and sort a bit of a flat spot and poor low revs pick up so i'd be interested to know if it's works. It's £68 something delivered inc VAT.
BenG
Ben
Oct 26, 2011
482
Cove Bay, Aberdeen
Their website doesn't give a price. Seems they expect only garages to perform the cleaning. Don't see why I can't just spray it into the intake myself! Too cheap??
I'm a bit hesistant in case it dislodges a lump of carbon from the EGR/inlet which might cause engine damage.
joel81
12
I rang SP Diagnostics who sell it. They quoted £49.99 plus VAT and carriage. You can do it yourself as that's what i was thinking of doing with a mate to rev the engine appropriately. Apparently it;s only been on sale in the UK since January this year but I read about first on this forum so somebody has definitely used it on here.
rsrich
Newbie
Aug 23, 2006
208
www.turnpikeracing.co.uk
I have personally used it on a fair range of vehicles with a variety of issues :)
To be fair I'll be up front and disclose I have been involved from the start introducing the fluid to the automotive specific market. (It was developed originally for cleaning turbines in jet engines and power station turbine generators, as well as adopting for large marine turbo diesel engines, so has plenty of history in high-value markets that need it to work.)
But seriously, I'll avoid trying to sell it and give my personal experience of how it works - I have done for example a number of VAG group models (A6, Golf, Beetle, Octavia), Ford Mondeos of various versions, Mercedes A-class, Vauxhall Astras to name the ones that come to mind, all diesel turbos. The cars had a variety of issues from vague driveablity problems, with hesitations and slugish performance, through to hard faults due to sticking turbo vanes causing overboost and limp mode as soon as any load is applied. In every case the owners have reported at minimum, significant improvement and in most cases a transformation of driveability and power back to how it should be, and often reduction of exhaust smoke and potential fuel economy improvements.
Application is straightforward and involves introducing the fluid into the air intake (after the MAF sensor) as a fine spray in three stages at various rpms as described in the instructions supplied with the bottle. Whilst not actively marketed to individual public end users, it is available to garages and "enthusiasts".
To briefly explain how the material works - it is a water-based non-toxic material with a "surfactant" active ingredient. This works by the molecules attaching themselves to oily/carbon deposits in the air path (ie turbo compressor, intercooler, valves, possible EGR and exhaust turbine components) and then releasing them as tiny particles into the airstream, thereby stripping the deposits in thin layers deliberatley avoiding large chunks of material being dislodged and causing subsequent damage or blockage. (remember the jet turbines? they can't afford to have damaging particles passing through) There is no solvent as such in the material, and is not intended to "soak clean"
A significant number of units have been distributed since launch and feedback has been enthusiastic to say the least. It is important of course to diagnose the problem correctly in the first instance to be due to carbon/oil fouling for the treatment to be effective. Mechanical or electronic issues (including severe clogging which is verging on mechanical siezure) producing similar symptoms will of course not be magically fixed! :) It is also equally important to consider the possible reasons for the condition and establish if any other remedial work is required to avoid the condition recurring within a short interval.
Hope that helps :D
Edit - relevant post from Bill (ibizacupra) on this one too - http://www.seatcupra.net/forums/showthread.php?t=346219
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
It sounds very promising, aiming to fix both EGR-induced clogged inlet manifolds and sticky turbo vanes. Where can we get it from?
rsrich
Newbie
Aug 23, 2006
208
Either try your local parts distributor or contact SP Diagnostics directly -
http://www.spdiagnostics.com/index.php/products/workshop/revive-turbo-cleaner
To avoid disappointment please be realistic about what the treatment is physically able to do - as described previously it is a surface acting material which doesn't dislodge large chunks of deposit, so you can visualise that it will not be capable of removing thickly encrusted inlet manifold deposits which you are perhaps envisaging.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Fair comment. I'm expecting it to act mainly on the inlet manifold, as it will only have been through the turbocompressor at that point, and should still be intact. I'd not expect a surfactant to remove large chunks unless they were poorly attached.
I have to say I will be interested to see what effect it can have on the turbo VNT mechanism, as this is in the exhaust flow, so the surfactant will have been through the combustion chamber. Is it formulated to survive into the exhaust?
Jet engines have a tendency to burn very hot and not deposit much soot after the burners. Power station turbines are almost all steam turbines, where you'd be trying to clean off scale from the water. Neither of these translate directly into effectiveness in turbo-diesels, although the marine engines obviously do.
BenG
Ben
Oct 26, 2011
482
Cove Bay, Aberdeen
It's the 1.9TDI. I tried and failed to get the EGR valve off as I couldn't reach one of the two bolts attaching the exhaust gas inlet pipe flange to the base of the valve - it was too close to the cam cover to give any access for undoing the bolt.
BenG
Ben
Oct 26, 2011
482
Cove Bay, Aberdeen
Hope that helps :D
Thanks for the comments. Can I take it then that this product would not be of use in shifting the thick encrusted oily carbon deposits in an EGR valve / inlet manifold?
Also, does it work post combustion, in the turbo turbine?
Cheers,
Ben
rsrich
Newbie
Aug 23, 2006
208
The original jet and more so the power generation turbine (gas turbines predominantly) markets are VERY sensitive to operating efficiency which directly affects fuel useage. Power generation consider a cleaning cycle at 1-2% drop in efficiency which then results in a return to normal, a variation which they can measure and monitor online. In this case a large proportion of the cleaning action is on the compressor blades.
The automotive and marine diesel formulation of the fluid is a variation of the original turbine product.
Fluid reaches the exhaust turbine and VNT mechanisms in its raw state by passing through the engine during the valve overlap period.
The VNT mechanism is largely responsible for a lot of boost and driveability/response problems, as a result of becoming contaminated with oil and carbon, this can initially make the mechanism (and hence boost control) sluggish and ultimately mechanically bind up leading to loss of boost control and under/over-boost fault codes set. Due to the relatively delicate nature of the vane components, we are not talking about huge amounts of contamination to cause a problem.
Seatmann
Rough around the edges
Sep 16, 2010
5,541
10
Scotlanda
PD or non PD? What's the actual engine code? I'm just asking because I'm not that far away and might be able to assist.
Nam-uk
1,295
433
lancashire.
Wynns EGR clean i used that when i did my EGR, make sure you wear gloves though if you do get it, it melts the carbon into liquid it is like carb cleaner but 100 times more concentrated/powerfull.
