Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Leon » Leon Mk1
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 26-09-2012, 23:32   #1
Mattyboy1
Senior Member
Mattyboy1 has 30 points
Pcv valve
Is there a pcv valve on the seat Leon Cupra t 180. And also where is it located
Mattyboy1 is offline   Reply With Quote
Old 27-09-2012, 09:54   #2
Rob Kelz
Senior Member
Rob Kelz's Avatar
Rob Kelz has 10 points
Quote:
It comes from under the inlet and goes up to the breather pipe on the rocker mate
Rob Kelz is offline   Reply With Quote
Old 27-09-2012, 09:58   #3
Rob Kelz
Senior Member
Rob Kelz's Avatar
Take a look at this, you can get silicone replacement that replaces the white one on the right and the T piece
The replacement
http://www.creationsmotorsport.com/p...ail.php?pid=15
Old 27-09-2012, 10:11   #4
Mattyboy1
Senior Member
Cheers mate that's great
Old 27-09-2012, 10:27   #5
Mattyboy1
Senior Member
And does that pipe do away with the pcv valve aswell then.
Old 27-09-2012, 20:51   #6
Mattyboy1
Senior Member
Anyone got there pcv removed. I'm sure mine is in a different place to the one on the pic.
Old 27-09-2012, 21:26   #7
Mattyboy1
Senior Member
In the pic above it shows the pcv facing the front of the car. On mine it's to the left of the t piece right next to the pipe with a 90 degree bend . So my pcv is before the t piece facing the passenger side of the car. So in the pic above where the pcv valve is its just straight pipe.
Old 27-09-2012, 21:58   #8
Tr1ck
Tr1ck's Avatar
Tr1ck has 10 points
anyone replaced one before? if so what are they like to do?
__________________
My Mk1 Leon Cupra Project! http://www.seatcupra.net/forums/showthread.php?t=326812 Its a slow project
Tr1ck is offline   Reply With Quote
Old 28-09-2012, 09:11   #9
nd-photo.nl
Senior Member
nd-photo.nl's Avatar
nd-photo.nl has 80 points
I've replaced the upper and the one below the upper pipe (the wiggly one) and it was quite annoying to replace due to the lack of working space. Also the one-use clips are a bitch to unclamp. Havent replaced the one facing the front.
nd-photo.nl is offline   Reply With Quote
Old 28-09-2012, 09:20   #10
Mattyboy1
Senior Member
Quote:
Have you still got the pcv valve in place.
Old 28-09-2012, 09:53   #11
nd-photo.nl
Senior Member
Yes, the silicone replacement for the first below pipe only replaces the T-section
Old 28-09-2012, 10:01   #12
Lodey23
Senior Member
Lodey23's Avatar
Lodey23 has 10 points
I have none of that crappy pipe work left. I removed it all and put in a catch tank which now vents to atmosphere. Benefit is no more oily crap going back through the intake. No more boost/vacuum leaks because the Pcv system that's left is totally separate. But be aware if you don't use a catch tank with 19mm inlets to match your current pipes from the rocker cover and oil filter housing you risk doing some damage as the pressure builds up, I tried and fired the dipstick out along with a load of oil.
Lodey23 is offline   Reply With Quote
Old 28-09-2012, 10:07   #13
Mattyboy1
Senior Member
Quote:
Don't you get an oily smell in the car though. How hard is it to fit a catch tank.
Old 28-09-2012, 10:22   #14
nd-photo.nl
Senior Member
Im not using a Catch can, but have rerouted the upper crankcase pipe to a aluminium joiner which connects to piping under the car (in proximity to my cat).
So I've disconnected the hockey puck thingy. Check the clear braided tubing in the pictures below.
Bigger overview / DIY Heatshield 08-09-2012 by ND-Photo.nl, on Flickr
Airfilter in place / DIY Heatshield 08-09-2012 by ND-Photo.nl, on Flickr
Old 28-09-2012, 10:29   #15
Mattyboy1
Senior Member
Looks good mate but I'm new to seats and turbos and wouldn't have a clue where to start with that lol.
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 219
03cupra, 8988stacy, A.smith-Cupra, aaronb84, adam.d, Adman77, AdrianL, adzmofo, Alex.W, Andrewski, ARO, aviaa25, b3n, Bakes100, bangerstox10, barney501, Ben:, BlueCupra01, Bradz, bree9482, brookesmk4, Buckroger, Burton8, Cabbage, car.crash, ccclark, CD, Chaz, Chrisallen649, ChrisW16, chucky, ck00743, clownboot, cpcpeter, Crabby, cupra118118, Cupra20v, Cupra:Dan, CupraDan85, cuprajose, cuprapete, cuprar185, Cuprar72, cupratune, cutes6, czaki, Danio, DansFR, darren2611, davidcaffery, davis_luke, denzil691, Derekm2104, domin8or, Donny9835, doodle86, dylantuk, ecksjay, EL, Elvio Pestana, Evil R 225, ezza24, Foreviam, fyfe9, G412eth, g60stu, gaz700, Gazaho, george_seamons, Getgaff, Gex, ginger3131, Goodall, googujube, GrahamFR, GrantM, GREG_R84, Guizado, hamlyn, Hawkers, Haze, Hedgehog Dodger, heggie, Hpi_matrix, iDan, irf, J19 MRD, JackK, jackoni, JaffaKira, jakey, jamandspoon81, jambox, james291, james_cupra, Jamiethorley, jduggz08, jeroencupraR, joe-20vt-toledo, Joshkcupra, Kako51, kane88, KatPhlap, Keithslippery, klemenmico, Kr1s0121, Laidbackdaddy, LCR33, Lee1892, Leechy360, leegreenaway, Legojon, LeonFR 1.8t, libiza2007, Lodey23, Luke158, LukeArrowsmith, lynneandcrow, M.Reed, M1C VX, mark-cupra, marshyc, martinius88, matroblee, Matt lcr, Mattias87, mattjc01, Matty1986, matty85, Mattyboy1, Max_K, MeBoosta, Mick288, mihal239, mike000, MikeAllam, milner575, mk4 cupra, MM95, mogz83, Molehill_Mike, MooRzy, Muttley, nally270lb,TQE, nathan_20vt, nd-photo.nl, OldManPooley, Oneiros, Onni92, ozaudio, Pablo225, Paul B2010, paul6316, paulgtir, pete fr, phat purple one, phillbriggs, pita100, porksword28, powly1621, RACK, rbooth1984, Readiee1.8t, Red cupra dave, reece1591, Rev, RICKY3, Roach, roadrunner88, Rob Kelz, rogercupra, roiLaredo, Ryan6926, ryan7788, S's Cupra, SamsCupra, scott180, Seal_LCR, SeanH., Seat racer, Seatboy, seatturbopower, Shapin, shidoshi, sion_kwl, Smurfy, solway, spanner87, Spence, Sprogpole, sri_130, Stepup, steve7786, Steveboy86, Stuart83, stutro, swedey21, Sypher, the parrot, Tim_M, tom t, Tomibz, Tommyboy91, toosmiles, Tr1ck, treaclesponge, TRUMPY, turbomick, useyourname, virdi, vroomtshh, W11TTX, wakko, Wazzer261, wezy0, Will_s87, wisejason, Yatesey8527, ySoCereal
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
