Pcv valve
Dave's 57
14
Changed pcv valve but still have a light on the dash put a code reader on and it says the circuit is open P0444 code turn code off do a run turn car off then when i restart light is back on can anyone help
Thanks Dave
Dave's 57
14
Ok thanks will order a new N80 valve and check the fuses before i go to work will have to use the wifes car
Reactions: mty12345
Dave's 57
14
N80 valve replaced
Fuses checked and ok
Still shows 0444 code
What next charcoal cannister or new N80 valve any help will be welcome
Dave's 57
14
This is 2nd n80 valve since new year still shows 0444 code circuit open
Now developed a missfire but not showing on code reader
Anyone got any ideas as its really ticking me off
Thanks Dave
R3k1355
1,787
251
Yorkshire
Yea you should probably get VCDS on it and see what's going on. There's only so much you can do with the cheap units.
Dave's 57
14
I do know someone who has a snap on reader that as far as i know is up to date.Will that be any good
Dave
