VCDS - How To Guides
Phillips1795
171
Corby - Northamptonshire
Guide in progress, watch this space it will keep getting updated throughout the day and tomorrow!
This has been put together from JsyCuPrA (Kev) Researching on the internet and Phillips1795 (Zach) Making the adjustment on JsyCuPrA MK3 Leon FR.
AS ALWAYS DO A AUTO SCAN OF THE CAR FIRST AND SAVE IT SO YOU HAVE THE ORIGINAL CODING IF SOMETHING SHOULD HAPPEN TO GO WRONG.
I HOLD NO RESPONSIBILITY FOR WHAT YOU DO TO YOUR CAR SHOULD SOMETHING GO WRONG.
Passenger Mirror Lowering (Reverse)
1. Select 52 - Door Elect, Pass.
2. Select 07 - Coding
3. Select Long Coding Helper
4. Move to Byte 04
5. Enable Bit 2
6. Enable Bit 3
7. Select 09 - Centr. Elect.
8. Select 16 - Security Access
9. Input Security Code 31347 Click do it and yes if it brings up another box.
10. Select 10 - Adaptation
11. Choose from drop down - (15) Access Control 2-Spiegelabsenkung Bei Rueckwaertsfahrt
12. Set Value to Active - Click DO IT! and Yes to the other boxes that pop up
13. Choose from drop down - (20) Access Control 2-Menuesteuerung Spiegelabsenkung
14. Set Value to Active - Click DO IT! and Yes to the other boxes that pop up
15. IMPORTANT TO REMEMBER - On the mirror adjustment stalk keep it on the L for this to work
Alarm Chirps, Lock & Unlock
1. Select 09 - Centr. Elect.
2. Select 16 - Security Access
3. Input Security Code 31347 Click do it and yes if it brings up another box.
4. Select 10 - Adaptation
5. Choose from drop down - (1)-Ruckmeldungssingale-Akustische Rueckmeldung entriegeln
6. Adjust value to yes
7. Choose from drop down - (2)-Ruckmeldungssingale-Akustische Rueckmeldung verriegeln
8. Adjust value to yes
9. Choose from drop down - (8)-Ruckmeldungssingale-Akustische Rueckmeldung global
10. Adjust value to Active
11. Choose from drop down - (7)-Ruckmeldungssingale-Menuesteuerung Akustische Rueckmeldung
12. Adjust value to Active
13. Choose from drop down - (3)-Ruckmeldungssingale-Dauer der Akustischen Rueckmeldung vom einfachhorn
14. Adjust Value to what you want, we selected Normal
Phillips1795
171
Ah yeah will put that in! This is still in progress will get the bulk of it posted then make adjustments as suggestions are made including yours.
If anyone spots errors with this as it gets close to being finished please point them out.
shutcorea
210
Mexico
Thanks! here are some mods of what I enabled on my car:
Automatic windows when opening your doors. You know when you take the key of the ignition, your window is going up and someone, opens a door...normally, this will stop the window and you would need to either turn the key again or close the window with the remote. With this mod, the window will fully close even if you open a door with the key off the ignition.
- 09 - Cental Electrics
- Security Access - 16
- Enter access code 31347
- Adaptation - 10
- Choose (13)-Zugangskontrolle 2-Freigabenachlauf FH bei Tueroeffnen abbrechen auswählen
- Set value to inactive (the default option is Active)
Enable Carbon Fiber background on the FIS display:
- Select 17 - Instruments
- Adaptation - 10
- Select Displaydarstellung
- Change "Version 2" (default option is Version 1)
Phillips1795
171
Air Blower
1. Select 08 – Auto HVAC
2. Select 07 – Coding
4. Move to Byte 11
5. Bit 6 - Enable Blower Status Display in AUTO mode active
Staging / Needle Sweep
1. Select 17 - Instruments
4. Move to Byte 1
4. Enable Bit 0
Activation of rear lights as DRL’s
1. Select 09 – Cent. Elect.
2. Select 16 – Security Access
3. Input Security Code 31347 Click DO IT! And yes if it brings up other boxes
4. Select 10 – Adapation
5. Choose from drop down – (6)-Tagfahrlicht-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht
6. Set Value to Active
5. Choose from drop down - (9)-Leuchte23SL HLC10 light function D23
6. Set value to – Tagfahrlicht / DRL’s
7. Click DO IT! And yes to the other boxes that pop up
8. Stay in the same page
9. Choose from drop down – (9)- Leuchte24SL HRA65 light function D24
10. Set value to - Tagfahrlicht / DRL’s
11. Stay in the same page
12. Choose from drop down – (9)- Leuchte26NSL LA72-light function D26
13. Set value to - Tagfahrlicht / DRL’s
14. Stay in the same page
15. Choose from drop down – (9)- Leuchte27NSL RC6-light function D27
16. Set value to - Tagfahrlicht / DRL’s
Switch Interior light / ambient lighting in the doors in all modes on Drive Select Color Red
4. Select 10 – Adaptation
5. Choose from drop down – (4)-Leuchte17TFL R BLK BLK SRB3TFL R SR KC3-lichtfunktion A17
6. Set value to – Inactive
7. Stay in same page
8. Choose from drop down – (5)- Leuchte16BLK SLB35BLK SL KC9- lichtfunktion B16
9. Set value to – Ambientelicht 3
simonali
834
36
Wiltshire
How odd. I wonder if there has been an update since then that addresses it? Apparently there was a new beta released last week, but you have to change a setting in the software in order for it to download.
DEAN0
Old Git
Feb 1, 2006
5,439
Preston - UK
See the other thread mate, VCDS was all in Germany when connected to the car. Never had it on any other car before.
Sent from my SM-G900F using Tapatalk
Did you look further down the list of options ?
Just had a look around mine and on many of the options the german comes up first - if you scroll further down the options are repeated but in English.
Deleted member 98136
Just borrowed a mates genuine VCDS lead and changed a few items, items like "mirror dipping in reverse" and "alarm chirp" I activated but didn't work.
After a bit of head scratching, I discovered that new menus had been added in the CAR MENU on the infotainment system, once these were ticked all the added items are working a treat.
As this is not mentioned in the OPs excellent guide, I thought I might just mention it here.
altea-ego
176
Found a new one.
Display Engine profile mode on the instrument cluster MFD.
19 - Can Gateway
07 - Coding
Long encoding
Byte 8
Bit 4 - Display for drive Program functions in instrument cluster active. tick to enable.
When changing the mode, Sport/Normal/Eco or Cupra if you have one? The new mode will be briefly displayed on the dash display when changing mode.
I also found that it displays the mode when switching on the ignition which is actually more useful to remind you what mode it was left in.
Video clip of display
Also found another one which proves someone has a sense of humour.
"Seat ejection system installed"!!!!!!!!!!!!!!!!!!!
john doe
55
Found a new one.
19 - Can Gateway
07 - Coding
Long encoding
Byte 8
When changing the mode, Sport/Normal/Eco or Cupra if you have one? The new mode will be briefly displayed on the dash display.
Do you have a short video on how it looks like?
paulolourenco76
40
Edinburgh
So I just tried this one and it works, however, on my cupra it seems to get the Individual and Cupra modes mixed up showing Cupra when I select Individual and vice versa
Found a new one.
19 - Can Gateway
07 - Coding
Long encoding
Byte 8
gasman
question has been asked in another thread, but does anyone know how to change indicators in wing mirror to 'sweep'.
seen on you tube.
chrizsschwarz- moving indicators.
sorry not allowed to post link yet!!!
