Revotechnik
Go Back   SEAT Cupra.net - SEAT Forum » SEATCupra.net additional Resources » Frequently Asked Questions Section » Problem Issues Q&A
Problem Issues Q&A A place for common issues affecting any specific SEAT issue, or tuning problems. If you have problems and are looking for answers this maybe a place to start.
Reply
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 06-10-2005, 14:41   #1
lethargic
Posts: n/a
Temp Warning Light in Mornings
Now that the winter is coming close and mornings are colder it seems my car doesn't like it as much as me! I've got a Y (2001?) Ibiza Cupra (1.8 20vT) and every morning this week when I've started it up after 30 sec (ish) the warning light comes on the temp gauge and that BLOODY ANNOYING alarm (suppose it wouldn't be much good if it sang a nice tune to you) sounds three times. At first I thought it was fuses for fans as I've had one go before and carrying spares. No dice.
When I turn the engine off and on again 9 times out of 10 its gone away only to come back the next morning.
I'm in the middle of making one of those kits to use with that VAG diag prog everyone goes on about, but until I have all the parts I can't read error codes and can't afford to let a dealer have a look at the moment.
Does anyone have any ideas? I really don't want to kill my car by driving it but I have no choice due to work n all.
Old 06-10-2005, 15:27   #2
bentaw
Revo'd LCR
bentaw's Avatar
bentaw has 10 points
its a faulty sensor on ur coolant tank mine does it but just havnt had time to take it to SEAT to get it replaced under warrenty use the search mate and u will find more info
__________________
Revo'd to 250.2bhp and 301lbs ft. Next i need someone to detail my car then onto suspension
bentaw is offline   Reply With Quote
Old 11-10-2005, 18:51   #3
spinrs2k
spinrs2k's Avatar
spinrs2k has 10 points
yep, its an all to common problem, go to seat and get a new coolent header tank as the sensor is built into the tank, fit it and your problem will go happend to me few weeks after buying my ibiza
spinrs2k is offline   Reply With Quote
Old 12-10-2005, 17:02   #4
SamS3
Posts: n/a
Yep, i had the same issue, sensor on the coolant tank
Old 12-10-2005, 18:27   #5
wazo
wazo has 10 points
i had this problem and it was nothing to do with the temp sensor on the header tank i was running a low mixture of coolant therefore the water was getting hotter than normal even when its just warming up if you know what i mean there is a set per centage of coolant that needs to be mixed with the water at all times so if you find during the year you are topping up you water bottle with clear water you are indeed diluting the mix which will result in the temp light flashing
wazo is offline   Reply With Quote
Old 12-10-2005, 19:13   #6
spinrs2k
spinrs2k's Avatar
Quote:
if you buy the proper coolent from seat you dont need to mix anything with it, comes ready mixed so will never have that problem
Old 12-10-2005, 19:20   #7
wazo
wazo has 10 points
i did buy the proper coolant
Old 17-10-2005, 18:41   #8
lethargic
Posts: n/a
Thanks for all the answers, Iwill get to Seat when I have the money. Drove through a puddle last week when we had a sheeeite load of rain, good all engine sucked it up and have just paid loads for that to be cleaned out! Doh
Old 09-11-2005, 10:33   #9
GreyKnight
Senior Member
GreyKnight's Avatar
GreyKnight has 10 points
I've got this problem on mine now, started yesterday morning (first really chilly morning). Turn engine on from stone cold, temp warning light starts flashing and three loud beeps from the dash. Guess the car will be going back to the dealers again!
It's a bit worrying really, as it nears the start of its third year of existence there seem to be a number of niggling problems with it, mainly all electrical. It further reinforces my desire to change cars before the warranty runs out...
__________________
Lotus Elise and Ford Mondeo Titanium X Sport estate.
previously a flash red SEAT Leon Cupra R 225 with Revo (yes I do sometimes miss it)
GreyKnight is offline   Reply With Quote
Old 09-11-2005, 20:58   #10
lethargic
Posts: n/a
If they do find the fault can you post here. I've only got 2k before my next service so am going to wait for that. There does seem to be alot of common faults with these though and who ever designed the radio.......!
Old 10-11-2005, 10:07   #11
JIMYU
Senior Member
JIMYU's Avatar
JIMYU has 10 points
happened to me yesterday for the first time, and again this morning. doh
__________________
Integra Type-R...life begins at 60(00 rpm)
resto en paz K03s Ibiza Cupra
JIMYU is offline   Reply With Quote
Old 10-11-2005, 10:23   #12
Si
Southern MoFo!
Si's Avatar
Si has 10 points
Yeah, happens to me too. Not every morning, but usally when cold.
Advised the dealer but because its so intermittent they are unable to help me!
I'll try the coolant mixture but I don't see how that would help on a stone cold engine!
__________________
2006 LEON FR TFSI
Gone: 2003 LEON Cupra R
Si is offline   Reply With Quote
Old 10-11-2005, 10:33   #13
JIMYU
Senior Member
JIMYU's Avatar
JIMYU has 10 points
I've just put up a post asking for a price on new header tank. I don't think they cost much
__________________
Old 10-11-2005, 11:25   #14
JBS Sales
Posts: n/a
Hi
No I think they are less than a tenner.
Not hard to replace either.
But do it when all is cold!!!!
Old 10-11-2005, 19:23   #15
Blucupra
Blucupra has 10 points
I have the same problem at the moment. When it's colder then 10 degrees celsius the light flashes and three beep tones are heard.
After lets say 30-45 seconds the flashing light stops and the temperature builds up to the normal 90 degrees C. I will go to the dealer when i have got time. The price in the Netherlands is around 60 euro's (including fitting). That would be around 40 quid i think.
Jeffrey
Blucupra is offline   Reply With Quote
Old 14-11-2005, 21:48   #16
mozza42
Posts: n/a
I have the same problem.
Also my temperature guage intermittently works, I guess from the replies above that the two are not related though?
Old 15-11-2005, 09:58   #17
JBS Sales
Posts: n/a
Yes it could be.
Check your levels and also the strength of your coolant.
Then it could be the temp sensor that makes the guage read incorrect.
Sarah
Old 07-08-2006, 12:07   #18
captain chaos
captain chaos has 10 points
happened this morning to my LCR. wife almost had a nervous breakdown when trying to tell me sumt wrong wif car,. she knows how protective of my baby i am .will this manifest to total failure over time asit wont fail again
__________________
Captain Chaos at your service
captain chaos is offline   Reply With Quote
Old 07-08-2006, 15:07   #19
danny_lund1
Posts: n/a
Happened To Me Last Few Days I've Been T See What Is Was And Was Told Its The Temp Sensor But Not The One On/ In The Bottle But The Sensor On The Side Of The Engine, Seat Say £16 + Vat, And Sorted
Old 24-10-2007, 23:41   #20
satilaboy
satilaboy has 10 points
my warning light/beep came on a few weeks ago on a chilly morning. switched off the engine, back on and it didn't come on again. ..... Till today!
I had this problem early this year and took it to my dealer and had it sorted under warranty.
can't believe that at the merest hint of cold(ish) weather the bugger goes pop again!
just waiting for the door seals to go again!!! far to many faults come as standard with SEAT
__________________
SOLD 04 plate Leon Cupra, Revo'd up to the hinge end!!! SOLD
satilaboy is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 138
.liam., .Si., 03cupra, ajcannon, AlexGSi2000, AP2000, bakewell001, bazpro, beastgtir, BenSBB, bisto48, boajdm, Bogwoppit, bond007sur, boostjunkie, boqer123, BRB, calum2144, chorlton, chr15dude, Chri$, chris2r, ChrisG, cmc, Colin1, Conorked, cooperdj, Craig Senior, CraigSmith, craig_tdisport, czaki, Dan Cupra R, Dan K, dan1si, Darbo, Dave S, dave92en, daverave, davidcaffery, deek_cupra, dgmx5, Dione J, DlllonJ, Don Eason, Dubbernut, ets2k9, EvilKinevil, f15h, Fahim-mohammed, fran1987, garryw, Gazaho, Getgaff, GMH23, Gokiwi64, GreyKnight, grimbo108, gulzar, harj, Haydn1992, Haze, Heyitsme, Hullcupra225, IlsonDanni, irishmanr26, jamiea69, Jenko03, jmackay2, john_tdi, jon78, jonnie5, jordanwhite1993, junglebadman, Justin R, KarlB1, Kartracer69, KernowFR, Kevaloni, Krash, lcr.kenny, lcrsammy, LEAKYSEAT, Leeboy22001, living2xs, Lockey99, Loud, markh2908, Marshall, MartinDov, martinius88, mattyholmz89, Miss Hamilton, morf101, museumsteve, nazamin, odedb52, onvi-cupra, PenneyR280, peter_cupra197, PhilW, poliq, Rapidgrrr, richroberts, Robbie C, Ronby FR, rosscoger, Ross_Cupra-R, rover220, rv_y, sabri747, sacho, sas2003, scottym, seatcupra2001, SeatJay, SenorTrololo, Shak-310, Simon_93, SKRPhoenix, Smcdee, Srmtor, staza, steve m, surajb1, taylost3, Thafussa, TheProphet, thomasa, tipping44, TKINDUSTRIES, tonycane, TonyTwoToes, useyourname, wazza5, Weth82, wezza12, Will_s87, Zeeseat
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Remap NOT the cause of temp warning light! InvisibleName Problem Issues Q&A 4 18-07-2006 14:12
Temperature Light and warning sound SILVER FOX 20V Ibiza Mk3 9 23-11-2005 19:11
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
