Across the pond...
flieger
Hello all,
After seeing a post from Arin at APR about the results of one of your members new 3.31 Stage 2+ updates I thought I'd stop in over here and browse the site. I'm glad to see another VAG site with a huge following much like we enjoy on the VWVortex.
About me: I've been a VW guy my whole life, from the age of 15 I've owned nothing but a VW product. I started with a 1969 VW Kombi Transporter (Baywindow) and actually still own it. I've had many VW's over the years and I won't bore you with the list (as it's about 18 in total). My curent vehicle is a 2012 VWGolf R. I'll cut and paste the info from my build thread on Vortex below. I've done a few things to it but still have a ways to go until I'm finished. I can't post any pictures since the site won't allow me to do so until I have a post count of 15 so the link to then thread and the images will have to wait.
I'll be snooping around here looking for some ideas for my car and hopefully learning a little more about what you guys are driving on a daily basis.
Cheers-
George
Exterior:
OEM Euro black headlights (P/N: 5K19987534D)
OEM Euro LED tinted taillights w/fog
OEM Euro folding mirrors w/LED puddle lights & right side dip in reverse
OEM Euro rear view camera
OEM VW/Audi jack pad adapter kit (P/N: ECS10724KT)
OSRAM LED front turn bulbs
OSRAM LED rear turn bulbs
Bold-Sport piano black front VW badge
Bold-Sport piano black rear VW badge
Kerscher-Tuning Golf R front carbon splitter
UroTuning smoked marker lights
Clear Bra 18" front end wrap
Interior:
OEM Euro Recaro seats
OEM Euro headlight switch (P/N: 3C8941431BXSH)
OEM Euro dash cubby (P/N: 1K1857919)
OEM Euro cup holder w/bottle opener
OEM Euro door warning lights w/OSRAM LED inserts
OEM Euro First-aid kit strap (P/N: 1K6860266A9B)
OEM Audi S-Line Shift Knob (P/N: 8K0863278GXBA)
OEM Euro Climatronic w/Celsius dials (P/N: 5K0907044ES)
OEM Aluminum look glove box handle (P/N: 1K1857147D3Q7)
OEM Siemens VDO full-color instrument cluster
PODI Tru-Blue boost gauge
NewSouth MK6 Ventpod (P/N: TPB 025G)
Valentine 1 LE w/Blendmount & hidden mute button
VCDS test mule
Engine, Trans & Exhaust:
APR Stage 2+ v3.31 w/RFD Loaded EMCS ECU
APR RFD (P/N: MS100033)
APR 3" RSC Exhaust System w/Black Diamond tips (P/N: FE100047B)
APR Intercooler (P/N: IC100012)
APR HPFP (P/N: MS100016)
APR Boost tap (P/N: MS100030)
VWR Intake (P/N: VWRPJ012)
VWR Subframe mount (P/N: VWRPF003)
Forge Motorsport 2.0T FSI DV to Intake return Hose (P/N: FMRLH-BLK)
ECS Tuning Billet aluminum oil filter housing kit (P/N: ES2210310)
BFI "Clean Catch" - Crankcase Oil Separator TFSI (P/N: CCF001)
OEM Mk4 side-to-side lever - (P/N: 1J0711202J)
42DD Shifter bushing set (P/N: 42-455-013)
HPA 02M Short shifter (P/N: HVA-305-C)
USP Stainless steel clutch line (P/N: USP-004)
ECS 6-Speed clutch bleeder block (P/N: ES2586654)
NGK Laser platinum plugs (P/N: PFR7B)
HPA Haldex competition controller (P/N: OBR)
TyrolSport Solid shifter bracket bushings (P/N: SSBB)
OEM Porsche 911 coolant cap (P/N: 99110645701)
OEM Porsche 911 oil cap (P/N: 99110747500)
Suspension, Wheel & Tire
Neuspeed Gunmetal RSe07, et45, 18x8 w/Michelin Pilot Super Sports (Daily)
Neuspeed Black RSe07, et45, 18x8 w/Federal 595 RS-R (Track)
UniBrace XB
VWR RacingLine Sport springs (P/N: VWRPA016)
VWR RacingLine Front hollow 3-way adjustable sway (P/N: VWRPA014A)
VWR RacingLine Rear hollow 3-way adjustable sway (P/N: VWRPA015B)
VWR Performance Brake System (P/N: VWRPB003)
Stoptech Rear braided lines (P/N: 95.33515)
Motul 5.1 Brake fluid (P/N: 100951)
Whiteline Front swaybar endlinks (P/N: KLC167)
Whiteline Rear swaybar endlinks (P/N: KLC141)
SuperPro Lower control arms assembly (P/N: ALOY0001K- includes part number below)
SuperPro Control arm lower rear-bracket mount (P/N: ALOY3273-80K - included in kit above)
SuperPro Roll center adjustable ball joint (P/N: TRC0003)
TyrolSport DeadSet rigid subframe collar kit (P/N: TSDSKVW)
GMan_88
189
Reading
Welcome from another George :D Get posting as I want to seeee it!! I'm a big fan of Golfs also especially the R and R32 :p
flieger
Thanks all...as I dig around through the forum I see plenty of help to be given. Hopefully folks will be willing to take it for what it's worth from my years of stateside VAG experience. A few more posts and I'll get some pictures up.
