very odd?! Might be worth getting your compressor checked over coz it might be on its way out...Not 100% certain coz i tend to steer clear of working on car a/c coz its all a big bag of s***!
Rich - you got vag-com? Might save you a lot of guessing if it's throwing an error code.
If no error codes, go for a drive, get passenger to do some logging, and get them to switch aircon on and see what happens.
How are you getting out of limp mode - do you turn ignition on/off again? Or does turning the aircon off immediately let the car boost again?
Thought i'd update this.
The aircon isn't causing limp mode anymore, i replaced a silicon hose that had a split on its connection and JKM found a wire with a bad loose connection. Also they checked for fault codes and there wasn't even 1, lol. So all's good :D
