Arona 2020 passenger door 12V supply
May 13, 2023
Hi all, I've got myself some new LED straps for my 2020 arona, I've already installed the center console strips and the drivers door lights however each door needs a 12V supply to power the LED controller. In the drivers door I spliced off the 12V supply for the wing mirror control switch, however only the drivers door has this. Does anyone know where I can find and splice into another 12V supply for the other 3 doors. Or anywhere I can find a wiring diagram to investigate myself. Also bear in mind the 12V supply can only be powered when ignition is on.
Thanks for any advice!
Edit:
I know the window motor is 12V however I've seen you can't use it as the extra current pull for the lights sets off the window safety feature that stops anything getting stuck in the windows when they close.
May 13, 2023
Okay for future reference for anyone doing this kind of mod on a seat arona SE technology 2020 or of similar model the window switches in the passenger doors have 10v-12v
Brown being earth
Green with purple stripe being live
Reactions: Tell
