Brake pad wear sensor wiring
Rich.T
1,609
932
Morning all. Still got my 04 LCR. Brake pad warning light on and found to be disconnected. Anyone know what corners of the car i need to be searching for the wiring?
Cheers Rich
Rich.T
1,609
932
Thanks. Need to get hold of a trolley jack and take a look.
Thanks again 👍
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,199
1,038
Kent
Yep only 1 wear sensor plug on these cars located on the nearside front.
Sent from my SM-S906B using Tapatalk
Reactions: Rich.T
Rich.T
1,609
932
Does it go into the same section of loom as the ABS wiring? Had a look under there best i could and theres no sign of it. Bizar!
Thai-wronghorse
Dec 3, 2015
2,199
1,038
Kent
Yes mate, it splits off the same section of loom.
Has it been tucked up out of the way as some brake pads don't have the sensor plug attached.
Reactions: mty12345
Rich.T
1,609
932
Hard to see. I need to get the wheel off really. I put new discs n pads on it a few years back and just cut the wire off the pad as there was nowhere for it to go. Remember the chap who id bought the car telling me the wiring was disconnected. So i assume the wiring has been bridged and tucked out of the way? Is the wiring a loupe system or just a single wire that earth's on the disc when the pad wears out?
