I believe this has been mentioned before on this forum, may be related to the ACC?Anyone any ideas why cruise control has stopped working? No errors on the infotainment screen. Error on the dash. Stopped working mid drive. View attachment 35564
I think that the ACC fault has car+cruise symbol, plus dirty sensor/camera warning.I believe this has been mentioned before on this forum, may be related to the ACC?
I know, which is why I posted the link above. ACC fault has a different image on the dash.My car doesn’t have ACC, unfortunately. I wish it did!
I do have access to a code reader. Luckily the cruise control is working now.Usually the cruise control will stop working if it has a fault with the brake or clutch switch as it won't know what inputs your providing.
I had this a few weeks back on my MK3 Leon and it was the brake lights stuck on. The rear washer pipe had disconnected by the bonnet release and soaked all of the electrical connectors behind the trim. Not ideal!
Have you got access to a code reader?
Hi mate what was the cause of the cruise control issue as this as just come on in my 2018 leon 1.8 tsiI do have access to a code reader. Luckily the cruise control is working now.
Not sure why it happened. It seemed to be spontaneous. Hasn’t happened since.Hi mate what was the cause of the cruise control issue as this as just come on in my 2018 leon 1.8 tsi
Have you got or know anyone with vcds/vag com or obd11? You'll be able to monitor all of the switch inputs. Clutch, brake pedal and the cruise stalk and buttons. This is the easiest way to start diagnosing the issue if no codes are present on a generic reader.Hi mate what was the cause of the cruise control issue as this as just come on in my 2018 leon 1.8 tsi
We can fit itMy car doesn’t have ACC, unfortunately. I wish it did!
