vngtx
i ran diagnostics on my 2.0 8v yesterday and came up with these faults, does anybody know how to fix them?
01247 : activated charcoal filter system solenoid valve 1 - N80 (open short circuit to positive)
00515 : hall sender - G40 (sporadic: signal outside tolerance)
00523: intake air temperature sender - G42 (open circuit to positive)
00523: intake air temperature sender - G42 (open circuit to earth)
00520: air mass/ flow meter - G70/G19 (sporadic, open short circuit to earth)
i can probably work out that the air temp singal is lost because part of the wiring is cut and there is no temp sensor attached (thanks very much previous owner ) and the wiring was touching. the rest im unsure about.
