Dipped beam headlights
rf860
3,575
scotland
Hi guys, at the weekend there i replaced my headlights bulbs with upgrade ones but they are not at the correct level. They point too much into the ground. How do i resolve this?
Any help would be appreciated!
mick-fr
Mégane F1 R26..
Dec 1, 2009
2,406
At a Shell garage..
Yeah.
Just need an allan key and a tape measure! Use the bottom diagram in that link as a guide. Mark on the wall where the beam should be and move the light to suit!
Easy! :)
R1ch85
1/4mile - 13.935 @ 100.54
Nov 9, 2006
1,675
Bristol
If all you've done is change the bulbs then they should not be out of alignment particularly. Double check the bulbs are seated correctly in the headlamp, and then check that the level adjuster next to the headlights switch in the cabin is set to zero.
