Ok, tbh I'm not 100% sure what turbin is saying - I know you can install the other way around to change the noise of them...
...but is the general consensus to go for the green or yellow spring? Thanks.
What turbins saying is that the dump valve works by vacuum lifting a piston allowing the air to flow through the valve, the one entry or exit pipe is on the side so acts on the side of the piston as opposed to on the spring, the other is directly under the piston so acts against the spring, if the pressure side is on the bottom acting against the spring it can help to push the piston and with a weak spring maybe even push it enough to dump the pressure, acting on the side of the piston it cant affect it as much.
If that makes sense.
