m0rk said:But it says "BRAND NEW KWP 2000 ECU Flasher + complete Software package + 30.000 ECU Tunning Files"
So it comes with files
you presume that all these 'tuners' do anything other than buy predefined files... even the so called custom mappers just do this.
Only a few pieces of software allow for adjustments - and if you don't have hacked versions, they're dear.
muddyboots said:What kit do you use then, and what extra safeguards do you take to prevent losing power to the ECU ?
micky 32 said:its a risk with any tuning hardware.
yellowperil said:Correct, but you can do a few things to reduce the risk ie watching the voltage, flashing while you have the battery on charge, removing the fuse for the cooling fan so that doesnt cut in and drain power during the flashing.
Also its just as important that the computer has plenty of power, dont use a laptop with a low battery!
Atleast using decent equipment like flashbooster you can sort out most mistakes using the flashbooster toolbox.
Tuning cars is not just having the correct equipment, its even more important to have the backup and experience behind you. All ECU flashing equipment is useless without a quality tuning file and you wont find them on ebay at £9.99 a disk!
muddyboots said:Right I understand.
However, having a display showing voltage is all well and good, but if you lost power for some reason (dodgy connection etc) it's only going to confirm that it's happened, rather than prevent it ? Or does it provide some kind of backup supply ?
Chiron said:Right then,
A follow up to the original bit of my post. The re-flasher off ebay arrived today and I've been doing a bit of investigating with it. First of all the interface is a fairly proffesional bit of kit, USB interface and a well manufactured surface-mount PCB using some quality components. The casing is robust and well moulded and the leads and connectors are also high quality. After a bit of digging I discovered that the unit is actually made by a company called Telway www.one-stop-factory.com and appears to be compatible with VAG-COM as well.
The interesting bit is the selection of tuning files. There are thousands of them and all appear to be genuine ( it would be hard to produce that many fakes). When viewed in a HEX editor you can see the maps. They are also strucutred into directories that makes me think that this entire collection has been copied from somewhere. Most of the files and directories are in Italian and there are several pointers to the fact that they were created by an Italian company and the name Piovan Franco crops up a lot. There are also references to WinOLS.
I will report back when I discover some more info.
yellowperil said:These interfaces may be OK for doing your own car but its another matter if you have paying customers, who is going to tell them if this hardware melts and fries the ECU in the process!
I must admit some of the ebay stuff is much better than others.
The main advantage with something like byteshooter is the range of cars it covers, including the 1.8 T and 2.0 petrols and the EDC16 diesels
As for files, find a supplier you are happy with and stick with them. I sure wouldnt want any ebay software running my car!
wild willy said:I have APR stage 1 software which i'm very happy with, but i'd like to try custom code too. Can i use one of these cheap tools to copy my stock, APR and cc software so that i can chose which one to run at any one time, since each software code is sevral hundred pounds i cannot afford to erase them with another code. I have no need for any base maps and only require the tool to save and restore my own maps so am i right in thinking i will have no imobilser issues.
Cheers.
