EML Light
k1_cupra
66
Had EML come on today, got it plugged in and came up with this fault code
Camshaft timing adjustment: open circuit P1531 no signal/no communication
Anybody come across this before?
Car in question 2008 Leon Cupra Engine code: BWJ
saedster
**BUMP**
I'm getting the same code,
005425 - Camshaft Timing Adjustment
P1531 - 004 - Open Circuit
Having loads of issues with the car and tryna isolate them one by one. not sure what this means or what i need to change/adjust to fix this
saedster
realized one of my sensors is broken- well non existent and not plugged in. its the one just north of the HPFP , is that the cam sensor?
saedster
if someone could please confirm part number for the cam sensor that would be great cause im confused as it seems that the part should be tilted but the one I'm finding is straight, which is 06C905163B
saedster
thanks I realized that the plug for the sensor had broken off so the wires off the female plug were soldered onto the sensor by the previous owner. looking to replace this now and will hopefully fix my rough idle / throttle body opening only 45 degrees
