Hi Guy's,
Wow, lots of posts. Thanks for the insight. Mine seems to be showing exactly the same symptoms as yella Beeza.
The stealers have had it for a week and have decided to change the ECU. they ordered it last Saturday but .Yes youv'e guessed it , there are non in stock
and it is now on back order, which could mean anything up to a months wait
they have had it 3 times now since i bought the car 5 weeks ago, but I got their service log sheet since they aquired the car and it showed that they had already looked at the
problem a couple of months back when it was supposedly fast idling at 2k rpm but obviously didn't fix it then either.
They have had it fully hooked up to the diagnostics when hot and cold, when the car is showing the symptoms and when not and as far as they can tell the diagnostics are not flagging anything up at all. I assume if it were this coolant/fuel temperature sensor issue that it would flag something up? i don't know what diagnostic system they use but i assume it is VAG com?
Any way, once the ECU is here and they try it we will see. If that don't fix it then they will have to try again
. i aint stopping hasseling them till its fixed, as it will be a long time out of warrenty and then it will be at my expense, let the robbing B*****ds pay out for a change
. I will keep you informed.
thanks again for the replies.
Moz
