I had been searching some time ago about maybe fitting some 6x9's in the rear of my mk4 Ibiza, but couldn't find any pictures or a definite answer if it was possible. A month or so ago, I looked behind the rear panels, and could see there looked to be loads of room, so I went ahead and some some Alpine 6x9's...
And today I finally found the time to fit them in the car! I also bought a small sheet of MDF, approx 0.75m x 0.75m and some brown bread sound deadening (was super cheap on ebay, think I paid £3 for two sheets 0.3m x 0.3m). I took it all to my work at 09:30, and this is how it happened...
Here's one of the speakers, Alpine SXE-6925.
I took the rear panel out on the driver side, then used the rear of the box the speakers came in to start making a template (mainly because it had a template for the speaker shape and hole positions).
Then after much adjusting, I ended up with this shape, using 3 existing holes, which I imagine must be for the factory speakers mounts (hopefully you can see the 3 small arrows I drew on the metal work.
So I cut out a piece of the MDF, and stupidly I thought that the MDF speaker mount could sit on the front of the metal work, just as the cardboard template is in the previous picture... After a trial fit of the MDF mount, then the plastic panel, the plastic panel would not quite fit as it was touching the speaker. So I had to mount the MDF mount on the rear of the metal work, and then found that the hole on the left hand side couldn't be used. I then had to slightly shorten the MDF mount, and create my own hole by drilling through the metal work (was nice and easy with a decent drill). To then mount the panel in place, I cut up a few small pieces of MDF, with a 6mm hole in as clearance for mounting screws to the metal work. Because of the contour/shape of the metal work, you need to use small spacers to stand the mount off from the metal work correctly.
So below is the final MDF panel in position, plus another picture to show the drilled hole position, in relation to the previous hole position I was going to use. Even with the MDF mounted behind the metal work, there is still loads of room for the speakers.
And how does it sound? Together with the Alpine components in the doors, it sounds great! The 6x9's do add a nice depth/extra bass to the music. Maybe the best thing to do next would be to run the 6x9's off an amp...
Anyway, I hope this showed what can be fitted in the massive space there is behind the rear panel
