I know there are few threads about gearbox oil already but I'm hoping to get some opinions and feedback from other members.
I don't have any issues with changing gears but when I had a look underneath the car this past weekend and noticed that there was some oil on the black plastic protector. I jacked the car up and removed the plastic cover and noticed that there was a fair amount of dry oil with dirt and grit topside so I'm guessing that the oil had been there for a while. I traced the oil leak to the gearbox drain plug which was slightly loose.
The problem is, I don't know how much gearbox oil has been lost to the leak so I'd like to replace the existing oil. The car has done 51k miles
I read that the gearbox oil spec is G 052 171 A2 and I found a link on eBay for Febi Bilstein gearbox oil: http://www.ebay.co.uk/itm/371144916745
I've also read that the Fuchs TITAN SINTOFLUID FE SAE 75W Synthetic is also compatible:
http://www.ebay.co.uk/itm/161133108640
The question I have is: which gearbox oil should I use, Febi, Fuchs, or VW OEM?
Car is a 2007 TDI 2.0 16v Reference Sport 6 speed
TIA
TIA
