dingsdale wrote
Car in question is a '99 Toledo TDI 110 with 101,000 miles on the clock. Was driving it for a few hours on the motorway yesterday and it was fine. This morning when i drove off, the alternator warning light started flashing on and off intermittently and the temperature rose very quickly and got pretty hot (towards the 110 mark). But it stopped after about 10 minutes of driving. After letting it cool down the same thing happened again
There is a rattly/squeeky noise from either the alternator or water pump. The belt is in good condition, well tensioned and definetely not slipping. Is there any way to tell which is making the noise? Any advice would be hugely appreciated!
techie wrote
The water pump is cambelt driven so there isnt a direct connection between both.
dingsdale wrote
Definetely not cambelt driven mate - unless the alternator is cambelt driven too! The car manual even says so - you must be thinking of a different engine (its a mk2 toledo)
Luckily i've managed to find a car I can borrow for the week, so I can take it to the garage at the weekend. I'm hoping its the water pump as prices for them seem to be about 20~30 quid, and alternators are closer to 100!
Sorry, but techie is correct. The water pump on the TDI 110 engine is driven by the toothed belt which also drives the camshaft and the injection pump. The external v-belt drives the alternator, airconditioning compressor (if you have one) and the power steering pump.
I think you have two unrelated problems. The cooling
problem has all the hallmarks of water pump failure, a well-known
problem with these engines as a lot of them had plastic impellers fitted as standard, and they eventually break up. The
problem with replacing the water pump is not the cost of the pump but the amount of work needed to replace it. If you haven't had the cambelt replaced yet, then you should do so at the same time; even if you have had it changed once, it will be due again at 120K miles so it would be best to change it now along with the water pump. Make sure you get a metal-bladed replacement pump.
The alternator issue is more difficult to diagnose. If it is still the original alternator, I'd check the brushes first, they must be getting close to wearing out by now, and it's an easy item to check and replace. New brushes are 12mm long, if they are worn to less than 6mm then replace them.
