How to remove Cupra engine cover
NigelCupra
51
Warsash, South Coast
I know this is going to sound a bit lame, but how do you remove the engine cover on a Cupra? I have had a quick look and the cover seems to be connected to loads of things and I dont want to just yank at it and break someting.
TimSawf
865
South Manchester
Vehicles with engine code BWA
– Remove the suction hose (rear left).
– Remove the connector (rear left)
– Screw out the bolts (air intake, front right)
– Remove the engine cover, by pulling firmly upwards.
Vehicles with engine codes BWJ, CDLD, CDLA
– Disconnect hose from the attachment clamps (left)
Deleted member 94519
Sorry to drag this old thread up again - does anyone know if there's a genuine benefit to the engine cover beyond lending the engine bay some semblance of neatness if you're that way inclined? (I don't give a fudge as long as everything's easy to get to and easy to fix, hence given equal weighting I'd rather ditch it!)
Jun 25, 2012
920
Gateshead
It houses the oe Airfilter And air intake.
