LCR VCDS Logs..
Rivva
Want more power!!
Feb 12, 2004
569
Doncaster
After seeing cuprapetes thread around his logs it made me want to run the same blocks and see if the experts can see anything a miss with mine?
Hopefully the code comes up correctly so here it goes...
Also spec is:-
225 BAM
n249 bypass
V3 B5 3" TIP
3" Turbo back decat cobra exhaust system
s2000 open cone filter
Debaffled charge pipe
Always run on shell vpower
Has recently had new MAF and N75 aswell...
115 & 118
Code:
Monday	16	December	2013	23:17:41
1ML 906 032 A		1.8l R4/5VT      01 0001
	Group A:	'115				Group B:	'118				Group C:	Not Running
		RPM	Load	Absolute Pres.	Absolute Pres.		RPM	Temperature	Load	Absolute Pres.
	TIME					TIME					TIME
Marker	STAMP	/min	0%	mbar	mbar	STAMP	/min	°C	0%	mbar	STAMP
	0.01	2440	59.4	1830	1030	0.27	2520	15	95.3	1140
	0.57	2560	110.5	1740	1330	0.87	2640	15	70.2	1560
	1.17	2760	148.9	1780	1810	1.48	2840	15	62.7	1860
	1.78	2960	158.6	1780	1830	2.08	3080	13	62	1810
	2.38	3160	154.9	1780	1800	2.68	3280	12	61.2	1800
	2.98	3360	154.9	1790	1780	3.29	3480	12	61.2	1800
	3.59	3600	156.4	1800	1800	3.89	3680	12	62	1810
	4.19	3800	159.4	1810	1830	4.49	3920	12	61.2	1830
	4.79	4000	161.7	1800	1810	5.1	4120	12	60	1830
	5.4	4200	163.2	1800	1820	5.7	4320	13	58.8	1850
	6	4400	161.7	1800	1850	6.3	4520	14	56.1	1850
	6.6	4600	159.4	1790	1840	6.91	4680	14	51	1860
	7.21	4760	157.1	1790	1860	7.51	4880	15	43.1	1830
	7.81	4960	160.9	1780	1880	8.11	5080	15	15.3	1890
	8.42	5160	166.9	1810	1930	8.72	5240	16	0	1990
	9.02	5360	172.9	1850	2030	9.33	5440	17	0	2070
	9.62	5520	173.7	1880	2110	9.92	5640	18	0	2090
	10.24	5720	177.4	1890	2180	10.53	5800	18	0	2210
	10.84	5880	163.9	1890	2220	11.13	5960	19	0	2210
	11.44	6040	158.6	1860	2190	11.73	6080	20	0	2190
	12.05	6160	156.4	1820	2180	12.35	6200	20	0	2190
	12.65	6280	154.9	1790	2170	12.95	6360	21	0	2160
	13.25	6320	94	1010	2400	13.54	5880	20	0	1490
	13.85	5440	15	1010	1230	14.15	5000	17	0	1150
	14.45	4200	19.5	1010	1100	14.75	4120	17	0	1070
	15.05	4080	12.8	1010	1060	15.35	4040	17	0	1050
	15.66	3960	12.8	1010	1040	15.96	3880	18	0	1030
	18.07	3480	14.3	1010	1040	18.37	3400	18	0	1040
002 & 031
Code:
Monday	16	December	2013	23:15:39
	Group A:	'002				Group B:	'031				Group C:	Not Running
		RPM	Load	Inj. On Time	Mass Flow		Lambda Factor	Lambda Factor	Bin. Bits	Bin. Bits
	TIME					TIME					TIME
Marker	STAMP	/min	0%	ms	g/s	STAMP					STAMP
	0.29	2480	88.7	8.5	50.31	0.01	0.953	1
	0.9	2640	124.1	12.24	75.42	0.6	0.938	1
	1.51	2800	156.4	15.3	86	1.21	0.922	0.953
	2.12	3040	157.1	14.62	91	1.81	0.945	0.953
	2.72	3240	154.9	14.62	95.44	2.41	0.945	0.953
	3.32	3480	157.1	14.62	101.47	3.02	0.945	0.953
	3.92	3680	159.4	14.96	111.53	3.62	0.938	0.953
	4.53	3880	160.9	15.3	118.75	4.22	0.961	0.953
	5.13	4080	160.9	14.96	123.56	4.83	0.953	0.953
	5.73	4280	160.2	14.96	131.83	5.43	0.953	0.953
	6.34	4440	163.2	15.3	136.97	6.03	0.938	0.953
	6.94	4640	159.4	14.96	138.61	6.64	0.938	0.953
	7.54	4840	155.6	14.62	144.53	7.24	0.961	0.953
	8.15	5000	163.2	15.64	155.28	7.84	0.945	0.953
	8.75	5160	167.7	15.64	169.39	8.45	0.938	0.953
	9.35	5360	176.7	16.66	181.83	9.05	0.945	0.953
	9.96	5560	175.2	16.66	192.11	9.65	0.953	0.953
	10.56	5720	177.4	17	199.39	10.26	0.953	0.953
	11.16	5920	176.7	16.66	203.94	10.86	0.953	0.953
	11.77	6040	164.7	15.3	191.53	11.46	0.953	0.953
	12.38	6200	156.4	14.28	178.89	12.08	0.945	0.953
	12.98	5640	12.8	1.36	2.53	12.68	0.86	0.938
	13.58	5040	58.6	6.8	60.39	13.27	0.813	0.883
	14.18	5000	102.3	7.82	54.33	13.88	0.875	0.922
	14.78	4920	14.3	1.7	7.75	14.48	0.805	1
	15.39	4840	14.3	0	11.08	15.08	0.844	0.961
	15.99	4760	12	0	11.14	15.69	1.398	1.047
	16.59	4680	12	0	11.47	16.29	1.991	1.047
	17.19	4600	12.8	0	11.44	16.89	1.991	1.047
002 & 020
Code:
 Monday	16	December	2013	23:14:05
	Group A:	'002				Group B:	'020				Group C:	Not Running
		RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME					TIME
Marker	STAMP	/min	0%	ms	g/s	STAMP	CF	CF	CF	CF	STAMP
	0.3	2600	63.9	6.46	36.97	0.01	0	0	0	0
	0.9	2680	108.3	10.54	67.83	0.6	0	0	0	0
	1.51	2840	154.1	14.96	94.86	1.21	0	0	0	0
	2.11	3080	157.1	14.96	89.61	1.81	0	0	0	0
	2.72	3280	156.4	14.62	98.53	2.41	0	0	0	0
	3.32	3480	156.4	14.96	104.14	3.02	0	0	0	0
	3.92	3680	157.1	14.62	112.64	3.62	0	0	0	0
	4.53	3880	161.7	15.3	120.11	4.22	0	0	0	0
	5.13	4080	160.9	14.96	127.03	4.83	0	0	0	0
	5.73	4280	160.2	14.96	129.56	5.43	0	0	0	0
	6.34	4440	160.9	15.3	137.67	6.03	0	0	0	0
	6.94	4640	156.4	14.62	138.44	6.64	0	0	0	0
	7.54	4840	157.1	14.96	144.69	7.24	0	0	0	0
	8.15	5000	160.2	15.3	156.81	7.84	0	0	0	0
	8.75	5160	160.9	15.3	162.67	8.46	0	0	0	0
	9.35	5360	171.4	16.32	178.83	9.05	0	0	0	0
	9.96	5520	188	17.68	190.61	9.66	0	0	0	0
	10.56	5720	174.4	16.66	195.86	10.26	0	0	0	0
	11.18	5880	165.4	15.98	185.75	10.87	0	0	0	0
	11.77	6000	159.4	14.96	182.14	11.48	0	0	0	0
	12.38	6120	157.1	14.62	179.19	12.07	0	0	0	0
	12.98	6280	154.1	14.28	179.06	12.68	0	0	0	0
	13.59	6360	152.6	13.94	180.39	13.29	0	0	0	0
	14.18	6160	13.5	1.36	5.39	13.89	0	0	0	0
	14.78	5200	15	1.7	8.86	14.48	0	0	0	0
	15.39	5160	127.1	12.58	172.53	15.09	0	0	0	0
	15.99	5200	168.4	15.64	176.58	15.69	0	0	0	0
	16.6	4760	13.5	1.36	5.64	16.31	0	0	0	0
	17.2	4200	12	0	6.53	16.9	0	0	0	0
	17.8	4080	11.3	0	8.39	17.5	0	0	0	0
	18.41	4000	12	0	8.78	18.1	0	0	0	0
	19.01	3920	12	0	9.44	18.71	0	0	0	0
	19.61	3840	12	0	9.03	19.3	0	0	0	0
	20.22	3800	12.8	0	9.14	19.9	0	0	0	0
Any feedback on these is greatly appreciated want to get it running as well as possible before taking it to be mapped by Bill @ Badger5
806
Harlow
maf reading works out around 250 hp.
you have exactly the same mods as me except I have a massive foam pipercross cone and a 3" SFS tip. my maf reading works out the same as yours. also took mine to a rolling road and it come out at 250.9 hp lol. all looks ok to me but out of curiosity does yours go into limp mode when booting it in the cold weather?
when giving it some beans mine overboosts past what the standard map wants and puts the car into limp mode. once I get my front mount mine will also be going to badger5 to sort this and some more power :)
Rivva
Want more power!!
Feb 12, 2004
569
Doncaster
Haha, looking to get my FMIC next month as well then off to b5, only had the exhaust on for 3 days but done 400 miles and no limp mode! Just the EML come on is all! The exhaust system has totally transformed the car, I logged it last month and came out at 176gs so 222bhp I think, the only difference this time is the cobra system and it certainly feels like its added that sort of power, really chuffed with it.
Dec 5, 2012
806
Harlow
Yea the downpipe is so restrictive. The cobra system is mahoosive lol. Mine only goes into limp occasionally normally when I hold it out in 5 th gear. I've driven a mapped LCR and trust me it's a totally different animal lol can't wait to get mine done
