Hi!
I have a 1999 Leon mk1 and I recently encountered a problem. My old JVC aftermarket radio was working fine but decided to replace it for a newer bluetooth JVC one.
Got the new one and replaced it plug and play basically and I had the memory loss problem each time turning the car on. I had to turn off demo mode and beep and set the EQ, it was getting too much each day. I read thoroughly online and didn't find much about MY problem.
You're supposed to change the red and yellow wire because otherwise it won't save a thing.
I did that and well now my radio isn't working.
Replaced both car Radio fuse 15A and radio has it's own fuse 10A and I changed that too. Fuses are ok and wiring same as before.
What else should I check on this car because I tried the older JVC and that won't turn on as well, so it sounds like something else now?
I'm posting the JVC model and wiring at the moment. The constant current changes when I swap the yellow and red but something is wrong and I can't figure myself.
