Would it give any benefit over the EDL?
As far as I understand it, the EDL brakes a spinning wheel to cause torque to be diverted via the open diff to the wheel with grip.
What I don't know is whether the EDL works in a proportional way, i.e. modulating the braking force until the spinning wheel finds grip, or whether it's just a clumsy on/off method.
The Quaife would seem to proportion the torque to exactly match the grip ratio of the two driven wheels.
I think a mod like this in a FWD car could potentially give more of a performance boost than upping the power with a chip. My old RWD BMW was less powerful than my FR, but I could cover ground much quicker as I could use all the power, whereas the FR just spins it away in smoke. Any improvement in traction would be a big advantage.
Does anyone have any experience of these:
http://www.quaife.co.uk/Seat-Leon-02Q-Quaife-ATB-differential
Seems a good price for a potentially very effective upgrade.
How would it interact with the EDL already on the car? Would it just mean the EDL wouldn't cut in?
The price is good , but then have to pull out the eng/gboxdiff £XXX x dismantling the gboxdiff £xxxx x assembly of gboxdiff £xxx x refit into engine bay total cost around £2 - 2.5k.
I have fitted diffs when I had FIAT ABARTHS for hill climb/sprint work, its a long clean and precise work not a job for the average diy
I wouldn't say it was as much as that...
the 02Q looks easier / no harder than the 02M to remove from the Leon - and Diff fitting normally costs ~ £600 inc g/box oil
Quaife+edl= :)
Interesting technical article on LSDs, EDL etc.
http://www.houseofthud.com/differentials.htm
According to the last paragraph, the Quaife and EDL complement each other nicely and should *reduce* torque steer in FWD applications.
I've been told it'll cost slightly more to fit than a new clutch.
i had a clutch n diff fitted for 500 quid on an 02m 6 spd , it feels 100% , not that much torque steer ( you know its there tho) definatley is worth the money if you have issues with grip
Fabia vRS here, got a Quaife and it is definitely and unreservedly recommended if you want to get that power down on the road :)
Much easier to control power, more mechanical ability to drive out of corners/control slides/avoid them :)
