Hi Guys, I was on a ........ private road today and I thought I'd give the car some beans!
So from third gear to 4000rpm then 4th to 4000rpm and 5th then all the way as fast as the car would go.
I got to about 118mph and then there was no power, Im assuming thats probably the fastest my car can go with a passenger? (PD100 with a remap to 150bhp) the power then seemed to be like non existant so I assume thats as fast as the car will go,
So I gently slowed to 70mph and chucked the cruise control on I looked back again I was doing 65mph. I put my foot down again and there was no power, I dropped it into 4th and did the same again but still no power.
I'm assuming this is what you call "Limp mode" however there were no visual signs, This is the only time this has happened and I've given the car some beans a few times. Its only when I got to about 118mph.
I'm not going to be able to use the private road again for some time.
I turned the car off and back on a minute later and the car went back to normal.
Is my top speed 118 after the remap?
Should there be visual signs of limp mode?
Thanks all
Thanks all
