Code:
Group A: '003 Group B: '115 Group C: '020
Engine Speed Intake Air Mass Throttle Drive Ignition Engine Speed Engine Load Charge Pressure Charge Pressure Cylinder 1 Ignition Cylinder 2 Ignition Cylinder 3 Ignition Cylinder 4 Ignition
TIME Angle Sensor 1 Timing Angle TIME (specified Value) (actual Value) TIME Angle Delay Angle Delay Angle Delay Angle Delay
STAMP /min g/s % °BTDC STAMP /min % mbar mbar STAMP °KW °KW °KW °KW
0.3 2680 71.64 100 15 0.6 2800 145.1 2330 1950 0.01 0 0 0 0
1.2 3120 111.81 100 4.5 1.5 3280 191.7 2270 2460 0.9 3 0 6 3
2.11 3640 139.39 100 3.8 2.41 3800 191.7 2220 2490 1.81 3 0 6 3
3.01 4120 148.81 100 6.8 3.31 4320 186.5 2120 2360 2.71 3 3 5.3 3
3.92 4640 160.08 100 7.5 4.22 4800 191.7 2110 2220 3.62 3 3 5.3 6
4.82 5080 168.89 98.8 10.5 5.12 5200 172.9 2070 2140 4.53 6 9 5.3 6
5.73 5480 172.67 100 10.5 6.03 5600 164.7 2040 2030 5.44 6 9 4.5 6
6.64 5840 177.89 100 8.3 6.94 5920 155.6 1990 1930 6.33 5.3 8.3 7.5 5.3
7.54 6120 176.78 100 8.3 7.85 6200 149.6 1930 1910 7.25 5.3 8.3 7.5 5.3
8.45 6360 175.14 100 12 8.76 6480 139.8 1860 1830 8.14 5.3 7.5 6.8 4.5
9.35 6600 171.31 100 16.5 9.66 6600 79.7 1010 1700 9.05 4.5 7.5 6.8 4.5
18 January 2010 16:14:31
Code:
Group A: '003 Group B: '118 Group C: '031
Engine Speed Intake Air Mass Throttle Drive Ignition Engine Speed Intake Air Charge Pressure Charge Pressure Lambda Sensor Lambda Sensor Bin. Bits
TIME Angle Sensor 1 Timing Angle TIME Temperature Solenoid Valve (actual Value) TIME Current Value Specified Value
STAMP /min g/s % °BTDC STAMP /min °C % mbar STAMP
0.55 2920 76.03 98.8 21 0.01 2760 30 7.5 1310 0.25 0.977 1
1.47 3320 122.61 100 6.8 0.85 3040 30 86.3 1970 1.15 1.008 1
2.36 3800 136.33 100 6.8 1.76 3520 30 79.6 2450 2.06 0.984 0.961
3.27 4320 145.89 100 9 2.66 4000 32 82.7 2420 2.96 0.922 0.945
4.17 4760 154.83 100 9.8 3.57 4480 33 84.3 2310 3.87 0.883 0.906
5.09 5200 165.56 100 7.5 4.47 4920 36 83.9 2230 4.78 0.883 0.891
5.99 5560 167.33 100 8.3 5.38 5320 39 84.3 2100 5.68 0.867 0.883
6.9 5920 174.03 100 12 6.29 5680 41 85.1 1980 6.58 0.867 0.875
7.79 6160 176.5 100 8.3 7.2 6000 45 84.3 1950 7.49 0.875 0.883
8.71 6440 122.61 79.2 12.8 8.09 6280 47 80 1910 8.4 0.875 0.891
timing pull still pretty bad, used v power, reset ecu, new plugs only thing left is fuel filter.
can hear a slight hissing from engine bay, somewhere round the back of the block.
no fault codes present, but there is a noticeable surge in top gear around 70mph if i accelerate.
bottom end hesitation is better since fitting forge yellow 007p spring.
also injectors are noisy, but not sure how loud they should be
any ideas fellas?
