Oct 10, 2019
38
Greetings, is there a way to check your oil temp or pressure, either by some app or somehow on MFD, would be really cool to see your normal oil temp difference while crusing and flooring it.
Depends on the MFD you have mine the small one and I’m limited to only a few options. If it’s the bigger one I think it can be done.
It's old red style,2007. Is there an OBD app that can monitor it?
I’m not actually sure there is a sensor in for temp on the 2007, I’m going to be getting one fitted at some point. It’s not an option I’ve seen.
S3 has it from what I know,also MK5 GTI too which is "inferior" version of TFSI
