Red Light and acoustic sound.
FR Cool
50
19
Hi guys just got back from taking my Leon FR M1 for a spin and twice a red light flashed on for a second along with an acoustic sound. I carried on driving without any issues at all. Not sure which warning lamp lit up cos it was barely a second. Checked in the cars manual and apparently it could be one of two either the brakes or the oil pressure. Checked both oil and brake fluid levels but they are ok. Like I said I continued driving at higher speeds with no issue at all. Any help with this folks ?
Nam-uk
1,112
298
lancashire.
That could be the water expansion tank warning its a common issue (very load buzzer) even though your still at max level, you can remove the cap and use a screwdriver or something to scrap the two prongs inside bottle and that's the level sensor as they can have oxidation on them yet still look ok, done it myself and worked for ages but just changed bottle and cap as they were around 13 quid at time
mty12345
3,771
476
bristol
If it's the oil pressure, then it's possible that the pick up is clogged.
FR Cool
50
19
That could be the water expansion tank warning its a common issue (very load buzzer) even though your still at max level, you can remove the cap and use a screwdriver or something to scrap the two prongs inside bottle and that's the level sensor as they can have oxidation on them yet still look ok, done it myself and worked for ages but just changed bottle and cap as they were around 13 quid at S
FR Cool
50
19
Sorry I am not very mechanically minded but by water expansion tank I guess you mean the plastic container that contains the coolant is that so ? You said you changed the bottle and cap but where did you manage to find the proper one for the Seat Leon mk 1 ?
Battoussai
426
106
Portugal
Yes, the refered tank is indeed the plastic container globe that contains the coolant liquid. If you get out of coolant your car can overheat. That's why it beeps so loud and flashes red light. When the water is low, the bumps and twists can make the water goes below the metal sensor, causing alarms now and then. Just fill it up and see if the warnings stop.
FR Cool
50
19
Thanks dude for your advice but the coolant liquid container is not low at all so guess its cant be that. I am beginning to think that the light that lit up was the handbrake light. I am keeping an eye so that if it happens again I an able to locate the actual icon.
FR Cool
50
19
Just come back from a drive and this time I managed to get the dam red light its the handbrake light that comes on for a mere second accompanied by a few loud beeps. Gonna start by buying some Dot 4 brake fluid tomorrow and topping up the bottle but in all honestly difficult to tell if its actually low just by checking it.
Nam-uk
1,112
298
lancashire.
mine wasn't low and never leaked its was the prongs inside bottle that oxidized , worth trying just scrapping the prongs first, got the bottle and cap from seat from here but dave left seat now, but easy enough to find them
Rich.T
1,609
932
I bought one a couple of months ago from TPS. Can't remember the price but theyre not big money.
