Jul 17, 2022
22
Hi All, im looking at changing my gearbox oil (some of it came out when my drivseshaft decided to break), has around half a litre or a litre that came out when the driveshaft popped out. I've put the shaft back in but getting a crunch from reverse gear, also remembered the oil had leaked so i need to top it up. Whats the procedure? Fill through the reverse switch hole and how much do i need to put in? On the Corsas we keep putting oil in until it leaks out of the shaft area, whats the procedure for the Ibizas? If there a fill hole or some method of knowing when the gearbox has enough oil inside it?
