Springs Clunking After Coilies
rossekins
Hi There,
Just picked up and fitted some coilovers, was a massive ball ache to fit with front topmount retaining bolts snapping off the rubbers, but got there in the end,
i finished it and decided that it wasnt low enough on the rear, i kept the adjuster cup in but took the threaded ring out, now it sounds like i have a slight clunking noise from the rear sounds like the spring tinging around, it looks lined up but not too sure, the springs in the rear are bigger diameter wise at the top and wind thinner at the bottom where they fit in the adjuster, meaning that the original rubbers that sit on the top of the spring dont fit in the new springs.
does anyone know what the problem is?
Many Thanks In Advance!
Ross
