By "much better" I mean that listening to anything over 8 or 9 on the volume control doesn't start to breakup, the bass seems alot richer and vocals are smooth.
Thanks for the step-by-step fitted these yesterday and it makes a massive difference
Just wondering though in the step-by-step does mention where you fixed the little box that is part of the connections that come with the speakers, i have left it in the bubble wrapper and managed to wedge it inside the door panel.
Just wondering what everyone else did with it???
One other thing what are the speakers in the step-by-step as they look different to the ones i got 652.7i. maybe they have changed the design???
I secured the crossover boxes to the inside door frame using cable ties, Obviously you need to make sure that the location you choose doesnt foul the window mechanism when putting the window down, checked mine with the door panel still off and its fine, theres quite a bit of room in there really.
My main worry is that doing the change this way (disabling the built in tweeter) I would imagine brings the whole sound like it's coming from your feet. I remember the same thing with the standard speakers in my old 306. With that car though it was easy as hell to pop the door cards off and install components.
hey simmytt i got a qeustion...
on the fourth picture (starting from above)where you can see the original connector from the original speaker and you are holding another connector with black and red wires, also 2 of the the black and red wire's are looped on it, i geuss is is for the connection of the tweeter?
i would like to know the brand and type(number) of that connector
like that way it is fairly easy to connect and loop the tweeter...no soldering or electrical tape needed.
Many thanks
regards
Many thanks
regards
Many thanks
Hey simmytt,thanks for reaction
So, if i understand correctly, the connector comes withe the adaptors, for mounting youre new speakers?
offcourse i will have to ask it has to be for the leon 2?
thanks
Patrick
This all looks good - only but I don't get is about the tweeter. I want to retain use of the existing one - do I just not cut any wires to do this? Is there an issue in doing this? I assume there is a reason everyone has been disabling them...
