Tdi Faq
Stu B
DarthWombleIII & WombleII
Leon / Tolly Part number for expansion bottle :-
1j0121403b (VW Dealership supplied)
This covers the on Startup (Cold) Engine Temp Bleeeeeeeeeeeep Flash Light... Which can be over come quickly by just simply switching off & back on again, or Change the expansion bottle / Sensor top right fails but it is incorporated within the bottle..
muddyboots
Still hanging around
Oct 16, 2002
5,739
prc said:
A pic with relevant part locations on a tdi..
Excellent Paulo, now I know where my EGR valve is.... :thumbup:
Is this a non-PD engine, if so it might be useful to do a similar diagram of a PD engine, guess there must be some slight differences.
prc
Sooty Meister
The pic looks like a 90Hp TDI. I'll try to get a pic of a PD engine, possibly a 130 on/off an ibiza (seems to be the most used).
prc
Sooty Meister
Pic of a 130 engine...Very very similar to the 150.
prc
Sooty Meister
Sach Race Engineering Clutch for 130/150 PD's
In the quest for a replacement clutch for my car came across a few more from Sach Race Engineering... Have a couple of doc's that I will put up as soon as I have a chance. Information is as follows:
2 discs available:
1- Organic material disc ---- part# 881864 999980
2- Sinterized material disc ---- part # 881864 999969
1 uprated pressure plate:
part# 88 3082 999 753
Torque ratings:
organic disc + pressure plate 400Nm = 295ft-lb
sinterized disc + pressure plate 510Nm = 376 ft-lb
prc
Sooty Meister
160pd ibiza cupra intake for the ibiza 130pd (as provided by muddy.. :) )
6LL 129 621 - bumper end connecting bit
6LL 129 618 - main pipe from airbox
Instalation:
Referring to the parts as:
Front inlet -> Adaptor -> Pipe -> Airbox
...where the Adaptor & Pipe are the bits being changed, this is how I did it:
1) Remove cross-head screw from airbox, pull old pipe out of airbox so the end is free
2) Remove 2 torx screws from front inlet, lift whole assembly out.
3) Prise front inlet off of old adaptor & hose. Chuck the old adaptor & hose.
4) Fit new hose into airbox and refit the crosshead screw
5) Clip new adaptor into front inlet
6) Refit front inlet & new adaptor using 2 torx screws (whilst pushing new pipe down out of way)
7) Bend the new pipe over the new adaptor and push together, pretty fiddly, requires a fair bit of bending of the pipe (which is quite flexible).
