Hello All, Well last week I said that it was the best car I have ever owned but after the week I have had my thoughts are beginning to change First off it has took 2 different coolant sensors from GSF and none of those worked the needle on the dashboard did not budge took those back and got a full refund so all good, I then went to a different shop Discount Motor Spares and got a sensor from them the guy selling it to me was adamant that my engine is a AGU not an AUQ that is what he said when putting my reg in the computer so after a brief discussion I reluctantly brought it because it was not the same make as the other ones that I had tried from GSF Instead of being a Dark green it was more Luminous green and called Intermotor. I changed it again this time I lost a lot of coolant as I forgot to take the top of the coolant bottle first there must have been a bit of pressure in there cos as I popped it out I had a coolant shower lol, but hay small price to pay I suppose cos after refilling the coolant I turned the key and hey presto it worked I could not believe my eyes the needle was moving was so pleased with my self considering SEAT earlier in the day first would not give me the part number they said they don't give out part numbers the stroppy sod
he said they could supply and fit it for me for £120 but in the end I only paid £20 for the part and £5.00 on a bit more coolant stupid mistake of mine. But when my boyfriend was going out my passenger door window decided to brake on him he had it half open and needed to close it to lock car, He tried to go up but no movement just some bad noises tried to go down it did but would not stop until it had got to the bottom, tried to close again but nothing, He has had to strip the door by taking of the front panel and the place I paid to fix the leak a few years ago had glued the back plate to the door solid which made this very hard to get off, but eventually not sure how he got it off but he did to find the wire all chewed up in the bottom, He has had to wedge the window shut with 2 pieces of timber under it for now to keep it closed, but last night when it started to rain I went to check it and it was leaking so I have wrapped motors and other parts in plastic bags to protect against the rain. I think I have found the right part on Ebay Please could someone confirm this part is the right one? http://www.ebay.co.uk/itm/SEAT-LEON...837461A-NEW-/151518332445?hash=item234732461d In the mean time could any one advise what is best way to stop water coming in because the door is all open the panels have not been put back on he did not think it was worth it until I have the part for the window and there is heavy rain due today and tomorrow and I don't want to my electrics to get too wet? And does anyone know what is best product to reseal the panel back on to the door to stop leaks when I have replaced the parts?
Another thing when my partner was using the car the other day before the sensor was replaced he said car felt nice when he first got in it to go to pals house and when he was driving back home he put his foot down a little and he said car felt like it was hesitating one sec it had power in 2nd and 3rd gear then next it was flat no power like it was losing boost pressure when he pulled up at island car was trying to stall and revs bouncing like crazy and when he came home he gave me the keys and said he is never driving the car again as it always plays up with him and never me
. When I have read up on the brand of the sensor I have put in it says it helps with a lot of things, this is what it said on the website
What does a Coolant Temperature Sensor do?
The Coolant Temperature sensor changes resistance with the temperature. The Coolant Temperature sensor is critical to many PCM functions such as fuel injection, ignition timing, variable valve timing, and transmission shifting.
Could this be anything to do with how the car was acting when he was driving or could it be to do with the coil pack? as they have not been changed in about 5 years since I first had the car and remapped it the old coil packs went the night we had it remapped so maybe one of those have gone again I do know last time they went the engine management light came on but the light has not come on at all this time my mate plugged it in to VAG last night and no fault showed not even my old two errors so I think the new DV, coolant sensor and thermostat have sorted those but does 5 years for a set of coil packs to last, does that sound a bit long because a friend said they need to be changed every 2 years does anyone know as the VAG is not showing a fault but the same friend has said that it will only show a fault if two packs have gone as they only trigger an error when 2 go does anyone know if that is true?
We can hear a hissing noise when the car is on tick over it sounds like it is coming from the right hand side when the bonnet is up. I have checked pipes can't pin point out exactly where its coming from when inspecting so anyone know best place in Birmingham to go for smoke test to check for leaks please?
A couple of other things on a bit more positive note since the sensor has been changed and working the car seems more responsive the temperature gauge is working every time, The fans are working again on the front of the car with out the air con being switched on or keys in the ignition. My partner noticed that they were not working the other day when he used the car, I had not noticed that they were not working until he said something. I asked at my local garage and they said the fans must be working because when the air con button was pressed they began to spin, But after reading other post on SCN I was starting to fear the worst it was going to be an expensive fix but thankfully after changing the coolant sensor they are working again I don't know if that is useful for anyone else but the coolant sensor does affect your fans on the car.
Thanks for taking the time to read sorry the post is a bit long and maybe a bit
any comments and advise is very much appreciated
Michelle
he said they could supply and fit it for me for £120 but in the end I only paid £20 for the part and £5.00 on a bit more coolant stupid mistake of mine. But when my boyfriend was going out my passenger door window decided to brake on him he had it half open and needed to close it to lock car, He tried to go up but no movement just some bad noises tried to go down it did but would not stop until it had got to the bottom, tried to close again but nothing, He has had to strip the door by taking of the front panel and the place I paid to fix the leak a few years ago had glued the back plate to the door solid which made this very hard to get off, but eventually not sure how he got it off but he did to find the wire all chewed up in the bottom, He has had to wedge the window shut with 2 pieces of timber under it for now to keep it closed, but last night when it started to rain I went to check it and it was leaking so I have wrapped motors and other parts in plastic bags to protect against the rain. I think I have found the right part on Ebay Please could someone confirm this part is the right one? http://www.ebay.co.uk/itm/SEAT-LEON...837461A-NEW-/151518332445?hash=item234732461d In the mean time could any one advise what is best way to stop water coming in because the door is all open the panels have not been put back on he did not think it was worth it until I have the part for the window and there is heavy rain due today and tomorrow and I don't want to my electrics to get too wet? And does anyone know what is best product to reseal the panel back on to the door to stop leaks when I have replaced the parts?Another thing when my partner was using the car the other day before the sensor was replaced he said car felt nice when he first got in it to go to pals house and when he was driving back home he put his foot down a little and he said car felt like it was hesitating one sec it had power in 2nd and 3rd gear then next it was flat no power like it was losing boost pressure when he pulled up at island car was trying to stall and revs bouncing like crazy and when he came home he gave me the keys and said he is never driving the car again as it always plays up with him and never me
. When I have read up on the brand of the sensor I have put in it says it helps with a lot of things, this is what it said on the website What does a Coolant Temperature Sensor do?
Michelle
