hi folks, i have a revo stage 2 and i am running boost 7 and timing 6, any idea what the maximum boost should read on my gauge.
thanks
thanks
right ok, my car is an lcr and it peaks at about 20psi and then holds at about 17-18psi.
p.s its set at 7b and 6t
Mine peaks at 22psi and holds at 20 right round to 6.5k rpm!
But I'm not running Revo.
i bet that it doesnt..
Without!
A standard KO3's turbo can't possibly produce 20psi @ 6.5k. Its little head would explode That is just way beyond the limits of the hardware, no matter what map it has. It would be seriously going flat out for that, and the heat it prodeuces should make it back off, so if its not backing off, you'd be killing your turbo!
You sure your guage isn't faulty - have you tried Vag com?
Well gauge seems to be working ok! Haven't tried VAGcom but it stays right up there and have had no probs!
