Removing PD130 EGR valve for cleaning
Feb 1, 2007
1,602
Nottingham
Its a straight forward job if a little awkward.
The two bolts holding the pipe to the bottom of the egr will need to be removed before you can remove the bolts holding the egr to the intake.
other wise as above.
While you are there put a blanking plate with a 4mm hole in it to reduce the amount of gases going through the valve.
Glynn
