Standard vs Remapped boost & airflow readings?
-pseudonymous-
681
Hi guys. Can anybody tell me the peak boost and airflow readings for a standard and a stage 1 remapped Leon 2.0tfsi Cupra (237bhp). Any Vag-com logs would be handy!
Cheers.
Al
7,331
9
Should see approx 200 g/s from a standard Cupra. Could log mine tomorrow to confirm if you wish :)
-pseudonymous-
681
Cheers for that mate. Is your car completely standard? I would appreciate it if you could possibly do a log to confirm. I'd be interested to see what a remapped cupra should flow also...
Al
7,331
9
Yep. My car is completely standard :)
Edit - I have logged Cupras in Standard, Revo Stage 1, Revo Stage 2 and Revo Stage 2+ forms of tune, and lost the informaiton, but as memory serves, 250g/s is about the figure you get from stage 2 with bolt ons.
-pseudonymous-
681
Ok cool thanks for that. Any idea what a Revo stage 1 map should read? Also what the peak boost should be on stage 1 Revo. I've seen that quite a few people have remapped cupra's but there doesn't seem to be any vag-com logs floating about the forums to have a look at. :D
Al
7,331
9
Depends on the boost settings. I would assume an approx figure of 230g/s and perhaps 1.4 Bar of boost at setting 6 on a car with a remap alone. Perhaps Kev or Carl might pop in from Revo to confirm.
Al
7,331
9
OK so i logged my car tonight in bog standard trim (stock everything).
Max air flow reading was 200g/s and max boost was 0.9 Bar. Inlet temp was 30oC and outside temp was 13.5oC.
-pseudonymous-
681
Thanks for that mate. I did some logs the other night. Peak airflow was 220g/s and boost peaked at around 19psi (1.3bar) and dropped to around 13.5psi (0.9bar) to redline. This is on a standard cupra other than a Revo stage 1 remap set at B6 T5 F9.
Im not sure if these are healthy figures, but i certainly expected higher MAF readings than that.
Al
7,331
9
Add an S3 intercooler to see air flow of 201g/s, intake temp at 17oC and boost at 0.85 bar.at outside temp of 13.5oC
