mk2 Useful Parts + info List
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
as there is a few part numbers and tweaks and tricks about the forum that are all in the name of saving time/money i thought i'd start a parts list off for easier reference (any additions feel free to add:
Inner CV Driveshaft Bolts
As the VW original multi spline ones are well at best 'soft' and shouldn't be reused as you can gaurantee one will round off when rerplacing them use the stronger Allen headed version available from local Ford Dealer - cheaper too *edit 2009* now supplied Torx 6 Type but still just as strong and put VW ones to shame
pt/no 6769287
be 100% sure you replace the double washers as without these your shaft bolts will work themselves loose and usually drive the shaft out the bottom of through the gear box casing
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
Caliper Slider Pins
Lucas type Caliper Slider Pins
The Ibiza 256/280mm brakes share the same caliper but with different frames to which the slider pins have a habit of siezing up from road crud and lack of maintenance and usually need drilling out
VAG only supply them with a new complete frame and the GSF kit is only the rubbers to cover them with some grease but a supply is available.
FORD part number - F6141154 (pack of 2) £8.00 + vat roughly (inc grease)
can confirm they fit perfect to the front and will evaluate the rear also as i think they are shorter but i will update details as they come.
Rob ibiza cupra
just got my hands on a seat ibiza 2.0 16v 150bhp as standard just woundering what will i gain from a remap would it be bout 190 ? and what could you suggest to make it go quick, will i feel a different with fast road camshafts, and will alot of new ibiza parts fit in the 1999 model ? just wanting to make it into my little project, make a sleeper out of it, cheers.
Rob ibiza cupra
is it possible to make my 1999 ibiza cupra 16v 2.0 pop when it redlined what would i have to do to gain this ?
old 'uns
Modern Life is Rubbish...
Mar 20, 2003
1,627
walsall
Visit site
at least 151 unless yours is Big Pete's old one then it'll be 144:rofl:
cams possibly but probably not enough for the money involved
you could probably fit an air freshener, should fit both models
ignore the redline in every gear, it'll go pop alright
you'll spend a lot of money for little gain for what you appear to want
