Lack of power.
Ches94
15
Here's the issue, car will run fine and boost perfectly. After awhile once heated under acceleration the car lags as if it's missing no longer boosts as well as let's off a couple pops when letting off, this carries on constantly till I come to a stop and turn the engine off.
Problem really is the turbo doesn't seem to kick in.
At first I thought it was missing but holding the clutch in it will rev freely throughout the range.
Running stock map with decat, forge recirc valve and cone filter. Maybe this could be the cause. Checked stored faults found fault with turbo solenoid, idle mixture rich another rich mixture fault and lambda sensor fault (from decat).
Turn the recirc valve round the wrong way and it runs fine, just not healthy for the turbo obviously..
Remapping in a month or so. Or should o do it sooner due to running rich?
