Making customisations
Bestseany
48
Hi
There’s a few settings I want to change on my Cupra 300:
- chirp on lock/unlock
- rear DRLs
- mirror fold on single press of remote
- disable seatbelt chime
I bought a Carista dongle and used the app but it doesn’t have many mods for mine and none of the ones I want.
ODB11 is no good as I have an iPhone and VCDS is too expensive for relatively small changes.
Are there any other options?
noonoo63
375
8
Scotland
I have just done three of these changes using Carista albeit on android but as far as I am aware Carista should work with iphone as well. I changed chirp on lock/unlock single press for mirror fold as well as disable seat belt warning( which I put back on again) and needle sweep on start up. I am still experimenting with it to see what else it can do.
noonoo63
375
8
Scotland
The*Carista*adapter is open and compatible not only with the*Carista*app, but also with a multitude of third-party apps that offer various different features on both Android andiOS. Our adapter*works*with all ELM327-compatible apps on Android.28 Apr 2017
SRGTD
2,430
1,309
Have you considered getting a cheap android tablet to use with OBD11? This is what a Golf R owner (an Apple user) on one of the VW forums did to get around the issue of their phone being incompatible with OBD11.
Bestseany
48
What type of Leon have you got?
I saw needle sweep but it’s already enabled as it’s a Cupra.
I couldn’t see chirp or single press fold.
Bestseany
48
Yeah I thought about that. Would I be able to use the Carista dongle with it? It’s fully ELM compatible apparently.
Bestseany
48
It is definately in the carista menu see this video on youtube it is maybe explained in there albeit it is a bmw but think menus are all similar. https://youtu.be/3K0rP6p1bKs
I checked all the options and there weren’t many options under the first category (doors etc). What model of Leon have you got? Maybe the app just isn’t that good on the Cupra.
noonoo63
375
8
Scotland
I have the 1.4 tsi se see my signature.Also see the answer above. Says beep when locking with remote iirc.
Deleted member 103408
No OBD11 and VCDS (From memory) Both have custom dongles that are not compatible with any other app.
Bestseany
48
I checked my car on the website before I bought it. It does list most options but does say its listing options for an Audi A3 which is similar. Not similar enough though it would seem!
Hi
- rear DRLs
Sounds like you need to an Android device to run Carista (odd it does better on android than ios) or OBD11 (Which I think is better based on how much I have done with it)
So as I see it your options are
1/ You can add android to your iphone https://www.pcworld.com/article/196595/how_to_install_android_on_your_iphone.html
2/ You can buy a cheap android phone / tablet (This is option I would go for)
3/ You can add android to your windows pc https://www.howtogeek.com/179691/4-ways-to-run-android-on-your-pc-and-make-your-own-dual-os-system/
or you can find a better IOS device that does what you want (so far I have not seen one)
trebor
231
30
Worcester
Where abouts are you?
Maybe somebody local that has VCDS and can make the changes for you ?
Bestseany
48
Just thought I’d post an update about this.
I emailed the developers of Carista and it turns out it didn’t work because they hadn’t released an update for the facelift Leon yet.
They gave me access to the beta version and after a bit of testing and various updates, I now have made these changes:
- Chirp on lock/unlock
- Rear DRLs
- Seatbelt chime disable
- Ignition chime disable
- Passenger mirror drop on reverse (can’t remember if I needed Carista for this!)
- Mirror fold on single button press
- Auto window close when raining
- Increased microphone sensitivity
Not bad for £10!
KXL
KXL
Dec 15, 2016
1,581
197
London, UK
I'm thinking to do this as well with Carista (but with Ibiza), just for needle sweep, chirp when lock, and turn off those awful cornering fogs.
Wonder if I should download beta version, or pay the £9-£10 week pass.
Was the beta version free or? Should I be cheeky and say I too have the Leon facelift?
I thought you just went for the Pro Version (and took the one months free trial and cancelled at the end) rather than paying for a weekly pass.
Bestseany
48
When you first get the app you get a months free trial anyway.
They have to invite you to use the beta app. The beta is valid for 90 days, although it gets updated quite frequently which resets the counter.
It shouldn’t affect the warranty at all.
