Phillips1795
VCDS - How To Guides - MK3 Leon 5F
R4CK5
609
85
The gear is already in the top right corner isn't it?
Sent from my SM-G930F using Tapatalk
leongone
11
Lowest VCDS version required for coding
Hi,
Can anyone pls tell me what the lowest version of VCDS is required to code on 5F.
Thank you
g_berserk
Smartass in training
Oct 15, 2014
164
24
Monterrey, Mexico
12.12 will lack half of the helpers for long coding, but adaptations work fine for the most part.
there were a couple options I couldn't make to work on adaptations on 12.12, but funny enough, on 16.8 some other bits that worked in 12.12 threw an error :shrug:
R4CK5
609
85
Was having a play around with vcds the other day and turned off cornering lights, enabled driving mode display in fis and carbon background to infotainment.
Word of warning on the infotainment, I had to activate bit 2 not bit 3 to get carbon background so it's selecting the equivalent of the third bit essentially.
Also couldn't get convenience indicator blinks to do anything other than 3 despite the coding being accepted for both 4 and 5?
On my facelift as well, all access control 2 mods on central electrics need to skip straight to sub menus as access control 2 doesn't appear?
I've now enabled the driving mode display when changed in the fis but since doing this, when I push the driving mode button, the description of.each mode has gone and I just have a blank box and a blank button under the modes. Any ideas why this could be?
kvasir15
22
Glasgow
I used the guide in this photo to turn on the flashing ambient light when my indicators flash, I was assuming that indicating right - the right door card would flash but instead both flash? Can anyone tell me what I've done wrong or if I just made the wrong assumptions?
Sent from my ONEPLUS A3003 using Tapatalk
Deleted member 103408
^^^^afraid this is how it works for me as well, you can from memory change the way the left and right turn affect it but it is to both doors.
kvasir15
22
Glasgow
Yeah I was mucking about with it quite a bit and all I could to was get them to flash out of synch with the indicators but not individual sides
I made the following changes.
5/ Set to Tuerausstiegslicht links
14/ Set to Blinken rechts Hellphase
26/ Set to Blinken rechts aktiv (beide Phasen)
From memory this gave me a different output if turning right or left.
-antero-
60
14
Estonia
Hi....can u tell me how to activate sport HMI in MIB1 5.8" without navi....
It is not possible with MIB1.
Can anyone help me with VCDS error codes. Did a full scan and had couple errors:
Address 09: Cent. Elect. (J519) Labels: None
2 Faults Found
0531 - Footwell Illimunation
B11FF 01 [009] - Electrical Failure
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 68
Mileage: 86294 km
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 75
Mileage: 1048574 km
Address A9: Struct. Borne Sound (J869) Labels: None
1 Fault Found
0007 - Actuator for Structural Noise
P193B 00 [008] - Electrical Malfunction
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 110
Mileage: 86180 km
What they mean and how to fix them :D
galbo88
Can anybody recommend me on fully work vcds cable?
I have AliExpress 17.8 cable thar not working for long coding, dsg7 adaptation, just work for read faults.
I noticed on cable on obd2cartool “Vagcom 17.8 HEX CAN USB Interface VCDS 17.8.1 online update version “
Any body have experience with this? They say that it supports updates, is it correct?
sfmk2.
878
Cable Not Working
All,
I recently sold my Mk2 Facelift and bought a Mk3.
My VCDS 11.11 / cable now won't recognise any of my Mk3 modules.:shrug::confused:
Does anybody have an aftermarket OBD cable that works with a Mk3 / can tell me what it is / pm link me?
What versions of VCDS do you use for your Mk3?
Eager to get going with tweaks.
Thanks!
DEAN0
Old Git
Feb 1, 2006
5,297
305
Preston - UK
All,
Thanks!
I have VCDS 17.8 and a genuine hex+can usb cable.
No issues so far.
GTunney
270
20
Newcastle Upon Tyne UK
Just wondering but did anyone ever find a fix for turning the interior lights off when you have rear DRL activated?
Would ideally like to have rear DRL but keep interior lights off until headlights are on.
