Gen1 to Gen2 Upgrade
dptulp
I have a 2016 Ibiza FR Tech 1.4 EcoTsi with the Gen2 6.5'' Nav System with Full Link. My mum has a 2015MY Leon FR Tech 1.4 EcoTsi with the Gen1 5.8'' Nav system. Hypothetically, and without consideration of cost, is it possible to upgrade from the Gen1 to the Gen2 system with full-link? I know the 2016MY Leon has the Gen2, and is offered with the option to upgrade to full-link for £150.
Seat (JCT600 SHeffield) Have said they would not entertain a retrofit of the Gen2 on a 2015 Leon and would not give me a price. Other than the higher-resolution head unit, has anyone tried (and succeeded with this upgrade? I've seen 2nd hand 6.5'' head units on ebay for £150, which woul likely need coding, but is there anything else that needs to be changed?
Apologies if this has been answered elsewhere, i searched the forum first and spent most of the morning trying different google search terms to no avail.
DaFoot
299
Sheffield
www.dafoot.co.uk
No idea on afraid, have you tried the Barnsley SEAT dealer. Used to be Bristol Street, now cars2.
And hello from another Sheffield Leon owner :)
Sent from my E6653 using Tapatalk
leonlad
1,130
49
london
is it easy to go from the 5.8 5f0035858a to the 6.5" ?
just a case of removing component protection ?
cupra14
341
65
England
To be clear, I meant the previous reply to your original question. It's not just a matter of removing CP.
Lmbarrett83
1,538
619
Sheffield
Hi mate,
Doesn't sound like an easy job.
I got my MY16 Leon in November 15 through JCT Sheffield and I wanted to sort out full Link too.
It was a £150 activation fee, but when they looked into it the existing USB module needed replacing too. So you'll need a confirmation on the right parts.
Sent from my Pixel XL using Tapatalk
leonlad
1,130
49
london
What else needs to be done ?
Car manufacturers would be better off leaving a hole in the dash like they used to years ago and let the user decide what they want. I cant even upgrade the maps on the mib1 what a useless system
leonlad
1,130
49
london
i was under the impression if the car already had BT GPS it would be a straight swap but only an issue for cars without navi to begin with ?
Kothaex
133
12
Hey dude,
How did you get on with this? Found this thread in my own searching - devastated I couldn't buy a MY16+ or facelifted Leon, but I'm very happy with my 2014 Cupra... with the exception of the infotainment. MIB2 + Android auto would be a godsend.
svenik
22
Which air vents frame is suitable for the 8 inch screen is it this one? 5F1820951 or i just need to cut the original one from 5.8 inch ? 5F1819110D
Walone
1,567
432
Near Heathrow
You can't use the frame that is made for the 8 inch screen on an early car as the fixings on the frame are different depths, so you have to modify the aperture in the existing frame.
Reactions: svenik
leonlad
1,130
49
london
Can the 8" frame be modified to fit ?
leonlad
1,130
49
london
I don't see how, the 4 fixings that secure the vent assembly to the car are a different depth so the vents would protrude out from the rest of the dash.
Ok cheers i have not pulled the old one out yet to compare thought someone on here may have done it.
Will the old 6.5" still fit the old frame after its cut ?
