Alright chaps i made a thread last year about this but finally getting neck deep in it. bit of a lost post but looking for some expert advice...
got VCDS lite on it and stripped the interior out and still cant find **** after months of investigating.
So Only thing that works from the interior buttons or fob is the boot lock. If i turn the key in the barrel in drivers door it locks but nothing else does, and fob does not physically unlock it after. Ive scanned Central Convenience, no codes. Tested the communication to CAN BUS and CCM and every door is communicating fine, VCDS knows when the doors are open/closed/locked/unlocked same for windows, interior lights, footwell lights... all working fine
What reasons left are there that it would stop the c.locking from working? If it was a specific door lock module faulty it would show a code right?
Ive checked the loom between the door hinges under the tape and all fine, traced them back to the connectors in the A-pillar, all good. Opened the Comfort Module and its pristine inside. CAN BUS wires off the back of it look fine, between the boot latch : fine, - but the only place i cant access is the loom behind the horizontal metal support under the dash as id need to take the dash and maybe some of the steering column apart.. From my understanding the 2 orange wires are the CANBUS cables which send all the locking data, which will split off from the CCM to the rest of the doors... i could be wrong but i figured those are what i should be focusing on unless someone more experienced than me can chime in..
Guess my main question is, if there is a broken wire somewhere, after ruling out all the usual places where else should i look? Or is this been way overthought and its just dodgy door lock modules all around?..im lost so If anyone can help me narrow this down before i kill myself id be super grateful
cheers
cheers
