Fuel flap locked shut tried everything
Nov 2, 2022
When I tried filling up (on the red) the fuel flap didn't open when pressed, even after unlocking the whole car multiple times. I've read it's likely a solenoid malfunction and I tried all the common solutions; tapping around the area, unlocking multiple times while pressing it, holding it in and unlocking, and nothing has worked. I've even checked the central locking fuse and switched it with another one even though both haven't blown. There's not even a way in to the area through the boot and the only way to replace the actuator is under the fuel door.
I'm confident in changing the part if I could even get in to the area!
Is there anything I could try before I rip the whole flap off...
Thanks.
Nov 2, 2022
OKAY I managed to get mine open at least, by using my fingers around the actuator under the flap and wiggling and pulling and it popped off. The actuator pin is still stuck in and in the locked position and I'm surprised I got it open without damaging anything. However, now I can refuel and drive it :)
