Temperature gauge
seatleon87
16
Hi, I've got a MK1 seat Leon 1.4 with temperature gauge playing silly buggers, stationery it's at 90 but when driving it drops all the way to 60?!
My worse feel is head gasket
Anyone else had this or can share some advice I would be much appreciated!
mty12345
3,772
477
bristol
99.9% chance it's the thermostat. Classic symptoms of temp falling when driving.
iammooks
1,745
1,135
My new coolant temperature sensor fluctuates pretty wildly. I can be crawling in traffic and it'll drop in the same way you describe. It never quite gets to 90 either.
The main reason I don't change it again is because I lost half my coolant doing the job the last time, but then I'm guessing it affects engine management, so it might be best to change it.
Just make sure you're prepared to fill the coolant again.
andylong
490
A thermostat is a fairly crude device, but reliable and the difference in temperature between the coolant in the engine circuit Vs the radiator circuit can be alot so when the thermostat starts to open the cold coolant will drop the temperature fast.
It only really gets stable when the coolants in the 2 circuits get close, which is dependant on so many factors.
Unless you have a really good thermometer, don't get hung up on actual temperature but more how the system operates, or is the thermostat doing anything.
Reactions: iammooks
mty12345
3,772
477
bristol
1.8t should get to 90C in 5 mins and then stay there, any downward movement is almost certainly the thermostat stuck open. There is a drain tap on the bottom of the radiator, you can use that to drain part or all of the coolant with relitive ease. Engine not reaching operating temp causes reduced mpg and long term can cause engine wear due to excess fuel washing the bores.
seatleon87
16
So the saga continues, it's back to 60 not 90 at all now
Changed the thermostat and the thermostat sensor, any ideas?! 😭 At my Witt's end with it
andylong
490
Measure the temps with something else, a food thermometer for example.
It's possible your guage it not reading correctly
mty12345
3,772
477
bristol
If the gauge is just stuck at 60 and never rises at all, then it's a 99% chance that the fault lies with the temp sensor or the wiring, or possibly but unlikely the dash cluster
If the new thermostat was faulty then you would almost certainly see it get hot when in traffic or going uphill, but then cooling down again when coasting down a hill etc.
iammooks
1,745
1,135
I always tend to get Febi if there's not a Bosch part available, but a Febi one is what I've got in my car at the moment. I guess whatever the brand, sometimes they just go wrong.
seatleon87
16
Changed that sensor and it made no difference, I've since done a live data drive and the below is showing up, it's rinsing fuel as well
mty12345
3,772
477
bristol
I'm guessing that code is for one of the lambda sensors, but it's in a weird format. I can't see how that would effect the temp though.
Here are the pin outs for the CTS. 2 pins feed the ECU, 2 pins feed the dash. If you put a 300ohm resistor across the gauge pins in the plug, that shoukl give you roughly 90C on the gauge for testing your wiring
