Transmission fluid temperature not working
Dec 13, 2023
Hi,
I found that recently the transmission fluid temperature isn't working anymore. It just stays at nothing, those 3 dashes (---).
I've been on a 200km drive and it didn't move at all. I think it happened after some cold weather.
Anyone else had this issue?
Thanks!
tracktoy
388
274
Dont know the MK4 but is it possible to turn it off in the menu.
If you have a diagnostic device might be worth seeing if that shows the temp just to prove its sending the data
Dec 13, 2023
Yep, that was it. Just came home from a 30 km trip in city traffic and it showed up once it reached 50 degrees.
JM89
7
if you had this on you 200km trip then you probably drived verry slowly or something? i mean it worked after a 30km trip....
